Gear, Engine, and MTF Oils - Page 3 - Fuelly Forums
Old 07-13-2006, 10:59 AM   #21
I did it in the evening, around Nov 22 of last year. If I remember right, it was around 0 C ambient, and I compared the fluids cold. That help?
Old 07-13-2006, 12:04 PM   #22
95metro's Avatar
Oh, well, okay then. As usual you're 20 steps ahead of me...
95metro is offline   Reply With Quote
Old 07-13-2006, 10:26 PM   #23
GasSavers_Ryland's Avatar
they really are differnt from what I've seen, cutting oil is closer to gear oil, then it is to motor oil, and you don't want to use motor oil as a cutting oil because it can't take the presure, it just doesn't work well, however, like I said befor, some of the sulfer compounds in gear oil are not compatible with the bronze bushings in a Honda (and other) tranny, and they will attact, and destroy them, really I'm a little confused as to why honda chose those metals that would lead to them needing motor oil in a tranny, if gear oil would last longer, other then it being thiner, and I supose Honda did start out making motorcycles with a gear box connected to the crank case, so they shared oil.
Old 07-14-2006, 02:54 AM   #24
In my rabbit I switched to Amsoil gear oil and that made all the difference in the world in cold weather - couldn't get out of first gear when it was cold - shifted like a summer day after. Use what the manufacturer calls for for the type of oil the use a lighter grade or/and synthetic - bearings and load surface area determine the weight of oil needed in the design of the transmission.
Old 04-29-2010, 04:56 AM   #25
Originally Posted by 95metro View Post
A pdf on Redline's website confirmed this by helpfully stating the gear and engine viscosities. 75W90 gear oil is similar to 15W40 motor oil, but the GM/Penzoil Synchromesh is actually closer to 5W30 motor oil viscosity.
interesting, i had no idea.
Calendar picker for entering fuel-up date? delfuego Fuelly Web Support and Community News 1 07-19-2008 02:18 PM
