Wool Tuft Testing - MkIV Jetta - Fuelly Forums
Old 11-10-2007, 07:06 PM   #1
trebuchet03's Avatar
So I had a 200 mile drive today (which is why I didn't do the one tank of gas challenge contest thinger ), and before I left I added some bits of yarn.
For those wondering how to do it..... Here's some tips
* Pick a tuft color for good contrast (black and yellow in my case).
* Try to follow some sort of grid for placement with lines following what you think the air will do.
* Try to avoid tangles. If you expect an area will cause the strands to whip around, make sure there's enough clearance between each strand to prevent entanglement
Front:
I added a few more after this picture - and a couple long ones near the hood trailing edge to watch the hood<-->glass flow interaction/transition.
Rear:
Adjusted Rear:
45mph Hood:
Nice and straight.
45mph Glass:
Also nice and straight.
More coming in a flash, including results from drafting a semi o.0
ID:	894   Click image for larger version
ID:	895   Click image for larger version
ID:	896   Click image for larger version
ID:	897   Click image for larger version
11/12
Old 11-10-2007, 07:07 PM   #2
Rear Glass - 65mph - No Draft
Another Angle
The stills don't tell the entire picture... Some of those tufts did complete circles - wildly. While in the turbulant flow of a semi, this changed dramatically (see next post).
It looks like flow separation occurs rather quickly, something more likely to happen on a sedan with a steeper glass angle compared to a long sloping hatch lid.
Front Glass - 65mph - no Draft
Hood - 65mph - no Draft
Notice the long tufts near the trailing edge of the hood get sucked under - there was no chance of it getting pushed up onto the glass. Room for improvement methinks
ID:	899   Click image for larger version
ID:	900   Click image for larger version
ID:	901   Click image for larger version
11/12
Old 11-10-2007, 07:07 PM   #3
I have video... But it's going to take some time to get it online...
Hood - 65mph - behind a semi (104" wide)
A single photo doesn't say what's happening. The video shows that the string stay straight (they don't curl) but go through pulses of left and right motions. Large eddies coming off the rear of the semi truck making it easier for my car to cut through the air
Glass - 65mph -behind a semi (104" wide)
The same applies here.
Rear Glass - 65mph - behind a semi (104" wide)
Here's where the very interesting stuff happens. Not drafting anything, tufts wildly go in circles - occasionally completely detaching for a few moments. While behind the semi, not 1 tuft did a 360. But there was some tuft curling - indicating that the flow was either inconsistent and/or weak (likely both - especially the former). To me, this means the flow is sticking nearby.
Tuft conditions post experiment:
Rear tufts, post test... They are quite frayed - indicated wild changes. The fronts and some of the rear (near the sides and top) were completely fine
ID:	903   Click image for larger version
ID:	904   Click image for larger version
ID:	905   Click image for larger version
11/12
Old 11-10-2007, 07:07 PM   #4
This space for rent... Just in case I feel I need to upload more pictures for someone
11/12
Old 11-10-2007, 08:09 PM   #5
ajohnmeyer's Avatar
Send a message via AIM to ajohnmeyer
Nice shots so far. So have you come up with any ways to use all of the subjective "data" that you collected during your trip?
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." -The Drive By Truckers
Team OPEC Busters!
ajohnmeyer is offline   Reply With Quote
Old 11-10-2007, 08:20 PM   #6
ChrstphrR's Avatar
Lightbulb
Since I've a Mk IV like you, of course I'm interested in the results -- thanks for the pictures!
When I was waxing my Jetta a few weeks ago, in preparation for winter (hey, it's Canada, not Florida here!), I was thinking about the big gap between the top of the hood, and the cavity where the wipers reside.
It'd be a nice spot for a fairing, that still allows for the wipers to function.
I don't want to hijack the thread here, but I did want to throw out that idea, since you were pointing to that very spot on your tuft-testing.
ChrstphrR is offline   Reply With Quote
Old 11-10-2007, 08:29 PM   #7
Extra emphasis on subjective
Actually, ChrstphrR took the words from my mouth
Which is actually, if I recall correctly, a key point of an old Autospeed article.
Additionally, I want to do some research on methods to trip flow into turbulence.
Not at all It's perfectly on topic
11/12
Old 11-10-2007, 09:04 PM   #8
ajohnmeyer's Avatar
I have been thinking about the same thing for my Civic. The obvious solution (at least to me) is a cowl-induction style hood, as one would typically see on a camaro or other such muscle car. Unfortunately, this style doesn't find it's way into the "tuner" (read economy) car market. This is about as good as it gets....IF you have a 6th gen Civic.
looks like you Jetta folks have the same long odds on cowl hoods. Though there seems to be some hope on the adhesive-cowl front.
Team OPEC Busters!
Old 11-10-2007, 09:17 PM   #9
ChrstphrR's Avatar
Thumbs up
Well, digging about when you mentioned it... I think this is likely the Autospeed article you had in mind, no?
"Silencing Wiper Wind Noise" - Autospeed, Feb. 26, 2005
http://www.autospeed.com/cms/A_2445/article.html
It looks as though the fellow that did this article managed to quiet down wind noise, but didn't get any appreciable change in fuel economy.
Mind you, the modification he did is quite a bit smaller/shorter than I was envisioning while waxing my car -- the Kamm effect strikes again, I think.
It's also a stealthy change -- the prototype's noticable, but the finished deflector looks relatively stock in appearance.
Little elegant solutions like this make me regret changing away from Mech. Eng. :P
trebuchet03's post here, and Julian Edgar's article are both giving me the urge to go out and buy a ball of wool and some masking tape.
Old 11-10-2007, 09:21 PM   #10
treb, that's just wild seeing those pix!!!
Thanks for posting!
F150 Grille Block-Off Snax Experiments, Modifications and DIY 12 03-08-2007 06:49 PM
Transmission choice for best fuel economy Matt Timion General Fuel Topics 6 11-09-2005 08:37 AM
