Wheel turbulance Q for gurus. - Page 2 - Fuelly Forums
Old 07-27-2007, 06:19 PM   #11
Well, I still like it. :-)
Old 07-27-2007, 07:03 PM   #12
GasSavers_bobski's Avatar
Originally Posted by brucepick View Post
You need to chase down the wheel skirts built by basjoos and CO Zx2. Both have full front wheel skirts.
Basjoos' front skirts are hinged with wide rollers underneath so when he turns, the tire presses on the rollers and lifts part of the skirt up out of the way.
CO ZX2's uses stretchable rubber for part of the front skirt. I don't completely understand how it works; I think maybe the rubber stretches to let the tire do its thing. I don't know how/why there's no rubbing to damage the rubber, maybe he'll post here.
Hmm... Maybe this could be a legitimate use for "spinner" wheels and hubcaps. Instead of letting the spinner portion free-wheel like it's designed to, run a few U-shaped braces around the tire and anchor them to the steering knuckle. That way the spinner will be suported by the wheel, but won't actually spin with it. From there, you could attach hard wheel skirts to the spinner that would cover most of the wheel well opening... Scrapers could be attached as well. The skirt - being attached to the steering knuckle and wheel - would change angle with the wheel instead of colliding with it when steering the car.
The front and rear clearance relative to the fender lip could be a fraction of an inch, but the top would either need more clearance or have to be made of some kind of semi-rigid material like thick rubber. The top edge of the skirt might collide with the fender during typical suspension travel, and almost certainly would due to suspension travel while turning, thus the need for a flexible material.
AC on and fuel milage tdisr General Fuel Topics 5 05-24-2009 01:25 AM
Ability to comment on Fuel Tips randomic Fuelly Web Support and Community News 4 08-22-2008 12:25 AM
Why don't we have small Isuzu diesel pickups? Why!!?? omgwtfbyobbq Diesels 35 11-29-2006 10:00 PM
Sweden calling ! GasSavers_elg Introduce Yourself - New member Welcome 3 10-03-2006 12:17 PM
TSB-Technical Service Bulletin Compaq888 General Maintenance and Repair 5 03-20-2006 10:12 AM
