Wheel Spacers to emulate Insight? - Fuelly Forums
Old 09-17-2006, 01:37 AM   #1
cfg83's Avatar
Hello -
The Honda Insight has a smaller wheel track in the rear to help it's aerodynamics. Now, I would think that on a stock car, it is very difficult to reduce the wheel track (and the width!!!) of the rear of the car, but I do know that you can increase the wheel track on the front of the car because of this :
I saw this here :
http://www.spswebpage.com/store/inde...b56d40aa4627a0
Now, my opinion is that the real Aero-savings is coming from the tapering teardrop shape of the Insight, but I would like to pose the question of whether emulating the *relationship* between the front and the rear track of the Insight would be of Aero-benefit or not.
I say no, because if you can't have the teardrop shape of the car, it is better to have the front and rear wheels "inline".
Old 09-17-2006, 07:36 AM   #2
I say no as well.
Also, you'd need to consider the pain in the *** of putting new wheel studs on, which is annoying with civics. At least EFs, that is.
Old 09-17-2006, 08:01 AM   #3
Offsetting the wheels won't help without the benefit of the tapered shape. It might even make things worse, since you're increasing projected frontal area, and slightly upping the rear tires' rolling resistance on wet roads (they'd be partially forging their own way through the water, rather than just following the fronts).
Old 09-18-2006, 12:50 AM   #4
Thre previous answers have said it all , but a bit about wheel spacers , Don't use them unless you have to.
Spacers (which are illegal in many parts) increase the loads on the wheel bearings and when used on the front increase steering effort.
This increases dramaticaly as you move the centre of the tyre outward from the rotating point of the steering knuckle assembly.
It feels bad , and is dangerous , ....same applies to aftermarket wheels that have incorrect offset for that vehicle.
Only use spacers to bring steeing geometry back to normal and only as a last option.
Old 09-18-2006, 01:22 AM   #5
cfg83's Avatar
Hi Everyone -
Thanks for the info. Useless and dangerous too !
Old 09-18-2006, 08:42 AM   #6
Tuggin at the surly bonds
Silveredwings's Avatar
This would be especially evident if one wheel was skidding and the other one was not. The result is more likely than normal to cause the car to swerve if you hit the brakes.
Old 09-18-2006, 10:20 AM   #7
Moderator
GasSavers_DaX's Avatar
Originally Posted by SVOboy
I say no as well.
It's cake if you have a 30 ton press. 30 minute job.
Old 09-18-2006, 11:51 AM   #8
I think if you check the specs on your vehicles you may find that the front and rear wheel tracks are not the same width anyway. Usually the front is wider than the rear. . . funny thing is the Geo I HAD was shaped wider in front and narrower in the rear but you only really noticed it from above.
Old 09-19-2006, 05:54 AM   #9
Hi Silveredwings
My fathers had a car with the wrong offset mag wheels fitted (so as to fit wider tyres) and on acceleration it darted from left to right like a crazy snake , it amplifed the torque steering affect you can get with FWD , and as you said, braking was also affected .
Overall ,it was a shocking thing to drive , untill stock offset wheels were put back on.
Gas Cubby Feature Requests khenn iOS | Fuelly Mobile 24 09-23-2014 10:49 AM
Logbook entries do not load after a fuel-up Nakkiran Fuelly Web Support and Community News 2 08-22-2011 04:18 AM
AC on and fuel milage tdisr General Fuel Topics 5 05-24-2009 01:25 AM
Ability to comment on Fuel Tips randomic Fuelly Web Support and Community News 4 08-22-2008 12:25 AM
Happy 23rd Birthday "thisisntjared" zpiloto General Discussion (Off-Topic) 2 05-27-2006 11:47 AM
