what more can I do? - Page 2 - Fuelly Forums
Old 06-17-2007, 04:43 PM   #11
Originally Posted by kitcar View Post
. What I gotta do is change the rear end and tranny to synthetic fluids, if available. I know the rear end needs friction modifiers for the center pig.
NOTHING is above the frame line. You'd either have to move everything up or hang the belly pan on coat hangers.
One thing I don't understand is why Dodge put the gas tank on the same side as the driver. That weight distribution doesn't make sense.
Amsoil works real good - it did in my 3.9 any way .
The important part may be redirecting for a smooth flow of air - air deflectors ? near the low hanging stuff . Yes I hit my head on many of the parts you've mentioned working under mine! I fit without jacking the truck up . O'course I fit under the Focus without jacking it up too
Ya know I don't remember *what* side the filler was !? I'll take your word on that LOL
Old 06-17-2007, 05:53 PM   #12
minic6's Avatar
Better with cruise off is not hard to believe. Many cruise controls are much more aggressive than our driving styles. Wifes Buick will actually cause a downshift when I don't want it. Flat land long and flat would probably be better with cruise. I'm guessing on the way to your cabin you have lots of hills. Your control is probably much smoother than your cruise. Even the cruise is built with performance in mind. I think the belly pan is a good idea. There has been some pretty amazing things done with them. Angle it at the back from the diff up to the bumper.
minic6 is offline   Reply With Quote
Old 06-17-2007, 06:44 PM   #13
I better get you all some video of the underside of a Dakota.
Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan
Stop complaining and build a belly pan. :-) Hang it off coat hangers if you must. I'm gonna have to do some sort of heroic measures on mine. The Element must have originally been designed without a gas tank at all. When they figured out the oversight, they just dangled it underneath. Looks like they devoted 15 whole minutes to the design.
Old 06-18-2007, 02:00 AM   #14
You know, I just had an idea. A belly pan! I'll grab some cardboard from work and mock one up tonight.
Proud owner of Stinkerbutt!
[SIGPIC][/SIGPIC]
-Homebrew front air dam
-Homebrew side skirt
-Torza top bed cover
Old 06-18-2007, 02:49 AM   #15
Send a message via Yahoo to GasSavers_BMac
I measured the wheels today once I got the spare down. 14 inches wide, 6 lugs. 6 leafs on the rear springs. 9 inch limited slip. And I get 26 mpg off this crap. What I gotta do is change the rear end and tranny to synthetic fluids, if available. I know the rear end needs friction modifiers for the center pig.
My Dak has the same wheels til I changed them out to 7" wide rims. No mpg gain! Same as when I went to the BlackMagic150 electric fan, no mpg gains.
My Diff. is an 8-1/4" 3.55 posi that I had Mobil1 synthetic in til the last couple weeks when I went to Amsoil. Then it went out on me, hence the rebuild this week!
Mine has only 3 leafs and a helper/load leaf.
Time to do the mess around!
1998 Dodge Dakota Sport 5.2 auto,
Aero Cap,
Cam advanced 4 degrees,
MSD 6TN,
MSD Blaster2 Coil,
MSD 8.5mm SuperConductor wires,
Borg-Warner cap & button
Halo plugs,
PCV jar
and more to come...
GasSavers_BMac is offline   Reply With Quote
Old 06-18-2007, 02:55 AM   #16
And it's really not a parachute. It's more like big arse plastic coated steel anchor. The bumper stands off a good inch inch from the tailgate, the license plate frame has a one inch gap at the hitch point and the upper license plate frame also has a gap. Here's photos of the deal.
Hoe about taking off the plastic part of the rear bumper and drilling some 2 or 3" holes in there?
Aero Cap,
MSD 6TN,
MSD Blaster2 Coil,
Halo plugs,
PCV jar
and more to come...
Old 06-18-2007, 10:04 AM   #17
If I'm not mistaken there's some holes in it already. I'll check that out.
[SIGPIC][/SIGPIC]
Old 06-18-2007, 11:32 AM   #18
MnFocus said: Belly pan it
Bill in Houston said: Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan Belly pan
Oive' ....So ! Have you considered a belly pan ?
Old 06-18-2007, 02:28 PM   #19
You know, Mn.....I hadn't thought of that. I have a trash can lid I strap across my stomach. What the heck good that's going to do get me better mileage I don't know. I'd think putting something under the truck would work better. But....I'll try anything once.
Of course it's way the heck too hot tonight to screw around with that and it's (of course) going to rain tomorrow so no cardboard fabrication tonight.
[SIGPIC][/SIGPIC]
Old 06-18-2007, 02:34 PM   #20
What good ? It makes really cool sparks when you belly surf on the freeway (not to mention provides some measure of abrasion resistance ! Lets not talk about the frying pan effect though 'k ? )
Now as far as a 'truck pan' ? Well that may affect the aerodynamics ! It may also provide a slight protective plate to prevent moose hair from sticking to some of those parts that hang so low that ...anyway ...
Take a break from the heat ,slap back some suds (the beer tally is important for the next step ) and plan out this new fangled 'truck pan' you've been trying so hard to explain
