Wake size and overall drag - Page 2 - Fuelly Forums
Old 09-10-2007, 06:23 AM   #11
I've always wondered if drag factors for various vehicles were constants. To me it seems possible that as speeds get higher, certain laminar flows that don't interfere with each other at say 60 mph could possibly create havoc with one another at say 80 mph.
Old 09-14-2007, 03:21 PM   #12
oneinchsidehop's Avatar
Question
Originally Posted by MetroMPG View Post
Or as viewed from the rear, since it's projected area.
Would it be? I thought the purpose of a kamback or boat tail was to keep the flow attached as the projected area was reduced (approx a 5:1 or 7% slope), the reduction of the low pressure system statisticly diminishing when the reduction reached 50%, hence the abrupt chop off in a true kamback.
Mike
_______________________________________________
"If you want to save gas I suggest you permanently remove the drivers seat and steering wheel. That seems to help." -Oscar Halverson
oneinchsidehop is offline   Reply With Quote
Old 09-14-2007, 05:20 PM   #13
trebuchet03's Avatar
That is the projected area at a specific region of the vehicle. To calculate aero resistance, you only need the max cross section. This is because the cD already takes into consideration all of the aero features (such as a kammback).
11/12
Old 09-15-2007, 03:32 AM   #14
You bring up an important point. The effective area is that which is orthogonal to the resultant wind vector. Since there always is some sort of crosswind, paying attention to to what the frontal area looks like, not only from straight on, but also from partial angles to the left and right, is also important.
.... gives me a whole new perspective on wheel skirts :-)
lca13 is offline   Reply With Quote
Old 09-15-2007, 07:02 PM   #15
brucepick's Avatar
True that speed makes a difference.
From the little reading I did on aerodynamics (wikipedia mostly), I managed to learn that the formulas and calculations are slightly different for subsonic vs. supersonic speeds. Probably different for automotive speeds vs. small prop plane speeds.
If you're going to talk 60 mph vs. 80 mph, I don't know. I don't think the order of magnitude change is big enough to make much difference in the basic calculations and formulas used. But the simple fact of increasing from 60-80 mph alone is enough to increase the total drag considerably.
