wagon Kammback? - Fuelly Forums
Old 02-18-2008, 05:38 PM   #1
wagon Kammback?
I have a wagon as seen below
I am thinking about a few ideas to clean up the air as it leaves the back of the car.
1.
or
2. a partial boat tail.
personally I like the idea of a wing that directs the flow in a more beneficial direction.
The roof rack has to stay since the air bags are mounted directly below it and I'm a chicken.
Old 02-18-2008, 11:58 PM   #2
cfg83's Avatar
philip1 -
I've been wanting to do something for over a year. Here is a mock-up of what I am thinking of doing :
Attachment 1194
But, I have another test in progress right now, so I think it is a month away.
Old 02-19-2008, 09:40 AM   #3
philip 1,
When (if) you get a scangauge or other onboard mpg readout, leave it off while running the Autocross course. It depressed me to see that my runs (HS) consumes fuel at about three times the rate of typical daily driving.
What have you done to go into the STS class?
Old 02-19-2008, 01:23 PM   #4
Originally Posted by Lug_Nut View Post
philip 1,
I've actually retired the wagon from racing it's now just a driver. a scangauge is on my wants list.
Old 02-20-2008, 03:05 AM   #5
I find it hard to believe the roof racks are integral to any airbag system.
I can only assume you are talking about airbags mounted at the roof/headliner? Maybe they share a bolt with the external racks...but as long as you maintain a solid mount of the airbag...lose the racks
GasSavers_Loopie is offline   Reply With Quote
Old 02-20-2008, 01:27 PM   #6
the bolts for the rack are above the airbags and I'm scared to mess with them because of that.
Old 02-20-2008, 06:41 PM   #7
cfg83's Avatar
philip1 -
I understand your trepidation, but I am also curious. Maybe this is a question for www.saturnfans.com. I am sure that one of the online Saturn repair techs could give you a professional answer on this. I am thinking there must be a set of steps where you disconnect the battery, remove the racks in step a, b, c, d, and reconnect the battery. If you are not a member, I can ask the question for you.
Can an airbag deploy without being connected to the battery? The manuals always say that you should disconnect the battery to prevent the airbag from being deployed.
Old 02-20-2008, 07:09 PM   #8
I'm on saturnfans.com same name and everything. I have mentioned this there. So far no one has said go for it.
Old 02-20-2008, 07:28 PM   #9
cfg83's Avatar
philip1 -
Ok, I was being lazy and didn't search saturnfans. If they didn't give you the go, then I wouldn't do it either.
Old 02-21-2008, 03:09 PM   #10
after pondering this for a few days I have decided to try on my next 2 month cycle some delta VG's just ahead of the hatch gap and we will see if they make a difference.
Shifting back into D from N, highway coasting brucepick Transmissions and Running Gear 6 09-24-2007 07:22 AM
Road Trip LxMike General Discussion (Off-Topic) 3 11-26-2006 05:29 PM
I got a Nintendo Wii UfoTofU General Discussion (Off-Topic) 5 11-22-2006 05:44 PM
Link about Winter Formulated Gasoline n0rt0npr0 General Fuel Topics 0 11-08-2005 12:57 AM
Stock 21 mpg getting 29.8 mpg ... room for improvement b1gmoose General Fuel Topics 6 10-27-2005 08:00 PM
