wagon Kammback? - Page 3 - Fuelly Forums
Old 02-22-2008, 05:35 PM   #21
That's what I had in mind too.
I like Charles Bs' idea of pinching the wake inward with the roof rack extentions.
I wonder if adding a 'wing' like I illustrated above the roof extention ( lower spoiler ) would create a higher pressure to the airflow - again pinching the wake and forcing the wake to stay attached to the teardrop shape farther from the back of the car.
It would sort of a 'biplane wing' set up.
It would be easy to test - just strap a sheet of something to the top of the roof rack.
Nerds laugh at me is offline   Reply With Quote
Old 02-22-2008, 05:38 PM   #22
Originally Posted by charlesB View Post
I agree, why not embrace the roofracks and use them as part of a functional and stylish solution. Something like a SPORTKAMM would do the trick....
Did you draw this ? ( Nice ! )
Old 02-26-2008, 09:18 AM   #23
I'm still trying to figure out why I saw my best tank on my Escort wagon with two bikes strapped to the back...
I figure the Audi A2 gives us some good clues about how to proceed though...
http://en.wikipedia.org/wiki/Image:Audi_A2_L_Silber.jpg
Very low Cd.
I figure you can either use either a rear window air deflector type spoiler to bring air down the back, or use a surface extension to entrain flow. I've also been considering the possibility of a deflector extending back abover the windshield by 3 inches.... yes it gains CSA, but by making the forebody "fatter" at the top, it might cause the air to take a path at an angle further back, meaning that it attaches to the rear surface longer, and reduces base drag. Anyone with a wagon with a tilt up sunroof, might like to experiment as to whether overall aerodynamics seem improved with it up or closed.
On my '88 Voyager, with rather square tailgate edges, I am planning to try attaching quarter rounds cut from pool noodles around the hatch, hoping the curved surface will entrain more air behind the vehicle.
Recently saw a Chevrolet Aveo that had a negative incidence rear spoiler/deflector, that looked promising. Not sure what I'm doing for the back of the Escort when it's back together again, think it might just need a deflector to keep the air nailed down further back. May try tumble strips/turbulators around the back.
Be interesting to carve humps out of styrofoam and stick them on top see if they make a difference.
Old 02-28-2008, 09:29 AM   #24
Last summer I did some very informal testing with my Passat wagon with the sunroof open and closed. It is not a flip up design as you are talking about here but has a small piece at the front that snaps up to deflect air up slightly. I thought I was crazy but I consistantly was getting slightly better mileage with the sunroof open. Perhaps your theory explains it. When the weather gets nicer I will try a more serious A-B-A test!
Phil
Roadwarrior said:
"I figure you can either use either a rear window air deflector type spoiler to bring air down the back, or use a surface extension to entrain flow. I've also been considering the possibility of a deflector extending back abover the windshield by 3 inches.... yes it gains CSA, but by making the forebody "fatter" at the top, it might cause the air to take a path at an angle further back, meaning that it attaches to the rear surface longer, and reduces base drag. Anyone with a wagon with a tilt up sunroof, might like to experiment as to whether overall aerodynamics seem improved with it up or closed. "
philp100 is offline   Reply With Quote
Old 02-29-2008, 04:46 PM   #25
Patience is a virtue I don't seem to have....... So when my VG's arrived today, I went right out and installed them......So much for the two month average oh well. we'll see if it all helps then.
Old 03-02-2008, 05:26 AM   #26
last week I took a trip out of town this photo is upon returning.
Old 03-03-2008, 12:20 PM   #27
s2man's Avatar
I see you used your windshield washers a lot on the trip.
Roll on,
S2man
s2man is offline   Reply With Quote
Old 03-03-2008, 04:31 PM   #28
LOL that is after not using them for the whole winter I needed them and the resivoir was almost empty. DARN BUGS!!!!
Shifting back into D from N, highway coasting brucepick Transmissions and Running Gear 6 09-24-2007 07:22 AM
Road Trip LxMike General Discussion (Off-Topic) 3 11-26-2006 05:29 PM
I got a Nintendo Wii UfoTofU General Discussion (Off-Topic) 5 11-22-2006 05:44 PM
Link about Winter Formulated Gasoline n0rt0npr0 General Fuel Topics 0 11-08-2005 12:57 AM
Stock 21 mpg getting 29.8 mpg ... room for improvement b1gmoose General Fuel Topics 6 10-27-2005 08:00 PM
