Universal AirVortex - Anyone Use These? Will They Work? - Page 3 - Fuelly Forums
Old 09-10-2008, 11:34 PM   #21
well DUH! why not use a flexible magnetic vinyl strip? this way you could easily adjust your location until you found a best spot.
either that or smear some oil on top of your car and then drive around at high speed and find the "bubble" and mount your strip inside of that "bubble"
or i might just make some of these out of plexi:
site can be found here:
http://www.fuelsavers.com.au/
Oh! Be sure to not draft any trucks that happen to have these mounted on the side!
Now, I ride the Eternal winds once more! And none shall ever be my master!
LastBoyScout is offline   Reply With Quote
Old 12-06-2008, 10:00 AM   #22
Hmm, I've never seen the 'Universal AirVortex' before. Without having tested it myself, I'd suspect that they work work pretty well to prevent delamination. My reason? The shape is taken from NACA ducts... which work great to push and pull air from a flat surface without adding drag.
I'd bet that they work well in a highly turbulent area of a vehicle.
Jeff in Tucson
GoblinAero is offline   Reply With Quote
What is this stat? cavale Fuelly Web Support and Community News 1 09-03-2008 08:23 AM
TV Newsroom needs your help in MI. ANITA STORY General Fuel Topics 37 06-13-2007 02:07 PM
Visual representation of airflow behind car landspeed Aerodynamics 6 12-04-2006 02:58 PM
Gaslog entry blues Spule 4 General Discussion (Off-Topic) 5 10-25-2006 07:03 AM
Whats your concentration factor. zpiloto General Fuel Topics 15 09-30-2006 05:28 PM
