Underbody Panel - Fuelly Forums
Old 11-06-2007, 06:12 AM   #1
Underbody Panel
I have recently made a partial underbody pan, can i cover the whole bottom side of my car or are there portions of it i should leave uncovered. Other than the Oil drain plug.
73challenger is offline   Reply With Quote
Old 11-07-2007, 07:52 PM   #2
|V3|2D
thisisntjared's Avatar
maybe exhaust?
Old 11-07-2007, 08:46 PM   #3
yes cataylyst gets over 1200*f can melt/get sone stuf VERy hot.
Old 11-09-2007, 05:40 PM   #4
Cool
Around exhaust, and the back of the engine bay. If you were to completely cover the bottom of the engine bay, you would effectively seal the pimary exit for the airflow entering the engine bay. that... is not so good as then it won't enter the engine bay in the first place.
Toysrme is offline   Reply With Quote
Old 11-09-2007, 05:55 PM   #5
Hateful's Avatar
Send a message via AIM to Hateful
I doubt if you could stop all air from entering the engine bay if you tried to.
Hateful is offline   Reply With Quote
Old 11-09-2007, 06:48 PM   #6
lovemysan's Avatar
I covered the entire underside of the engine. I left only vents under the exhaust. I just fixed two access panels that allow easy entry to the oil filter and trans. Eventually I may put some hinges to make it easier to get to. It takes me about 10 minutes longer to change the oil because of the pan. It rarely runs hotter than 200f. In the hottest part of the year it ran 208f on the interstate at 80mph with a/c. The system was very taxed. But if I'd slowed to 70mph it would have been fine. Also I find that when I draft temps run a little higher. The cat is 2" inches from my pan and it shows no signs of heat damage. The muffler itself got very hot and cooked some paint off but thats it. Soon I will cover all the vents, seal the front wheel wells and rearrange the engine bay exhaust under the car.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Watch the Odo, not the speed blackbird General Fuel Topics 1 02-12-2010 04:34 AM
Picking up my VX on Sunday! Pics! RobbieVX Introduce Yourself - New member Welcome 34 06-19-2007 06:48 PM
electrical loads, real amp draw on the vx GasSavers_Ryland Experiments, Modifications and DIY 3 04-21-2007 09:13 PM
Grille block v2.0 a success! (kinda long) GasSavers_BluEyes Aerodynamics 3 02-17-2007 09:42 PM
High School Compaq888 General Discussion (Off-Topic) 17 11-26-2006 01:17 AM
