Ugh. First test a wash - Fuelly Forums
Old 06-21-2008, 09:00 PM   #1
Tried prototyping a grill block on the Escape. Put shipping tape over all the grill openings except the one on the bottom. I also covered the fog light air brakes (forward facing holes) since I don't have fog lights. Filling up before and after did not provide a measurable change in mileage from my normal highway rate of 23 mpg (speed limit all the way).
Temperatures seemed fine. I didn't expect there to be a problem with open highway.
The test was not rigorous. I had a piping gig about 55 miles away. Naturally, I had a head wind all the way up and after the gig, there was no offsetting tail wind coming back. No instrumentation (ScanGauge on order. Waiting...waiting...waiting <sound of foot tapping impatiently>)
I'll keep the tape on for a while. If I add a bow, I can tell people it's giftwrapped.
lowbridescape is offline   Reply With Quote
Old 06-22-2008, 02:01 PM   #2
i would have personally covered the bottom opening and left the grill part open. but you cant call a 55 mile jaunt a wash. keep with it as you need better conditions.
also, would you have gotten worse mileage with a head wind and not having everything covered up? thats another thing gotta think about too.
ophidia31 is offline   Reply With Quote
Old 06-22-2008, 02:13 PM   #3
Ford have been known to have aero truck grilles that cut off the airflow at a certain speed, by clever design. i.e. at 45 it goes through, at 65 it goes over.
Old 06-22-2008, 09:00 PM   #4
Yes the test condition were less than ideal in just about every way possible, but I had hoped it would at least throw me a bone or something. I'm hoping that taping the front of a brick isn't just going to result in a brick with tape on the front.
If the body drag is unproportionately present on the Escape (it is after all, a brick), it may be more amenable to rear treatments like cammbacks, vortex generators, and other ways to mitigate the wake. I'll get there eventually.
The only way I could see it turn off the flow into the upper surfaces would be if there was an air dam that would tend to ram air into the lower openings and pressurize the plenum in front of the radiator. The '01 Escape has almost no concept of an air dam. It has a bullet nose that would seem to shove air under the car. I haven't figured out a good air dam approach but it will definitely alter the appearance.
Temperatures are going up over the next week. So that should give me a chance to see if there is going to be an overtemp problem.
Old 06-23-2008, 07:06 AM   #5
Gassavers.org quote of the year?
Mph Caps billynjoanna General Fuel Topics 2 06-10-2007 12:38 PM
Miss matched tires zpiloto General Fuel Topics 4 02-16-2007 01:40 PM
Metro from the Ozarks! GasSavers_Waterboy Introduce Yourself - New member Welcome 2 08-19-2006 08:40 AM
