Turbulence - Friend or Foe? |Here's a lot of Aero info, not spread in several threads - Fuelly Forums
Old 06-23-2008, 11:06 PM   #18
sonyhome's Avatar
More turbulence links
I had done a mini survey on VGs in cleanmpg.com,here, which I'll recap and complement:
Vortex Generators - VGs:
Mitsubishi EVO MR $300
Air Tabs $2.50/ea (+10% MPG CR-V gen-1)
AirFlow Systems $10/25ft (I contacted them on FE and they honestly replied)
Vortekz $20/10pc
Fuel Savers AU$110/9pc (up to 11% savings)
Boundary Layer Energizers etc., not quite VGs:
UC Davis BLEs
Sinha Deturbulator tape (This claims up to 30% MPG increase, still in R&D)
Found in Bman83GL Deturbulator tape topic.
Zig-zag and dimple tape(2,3)
Spoilers
Spoilers (not wings) are used to detach the flow of air from the rear of the car to create a pocket of non-turbulent stagnant air behind the car to finish the air flow like a teardrop (makes a virtual boat tail) and reduce Cd caused by drag from poor rear aerodynamics. Used by modern wedge shaped hatchback cars.
(need references) see Citroen Cx or Toyota Prius.
Other stuff
Aerody.org articles
Wolf-Heinrich Hucho - Aerodynamics of Road Vehicles From Fluid Mechanics to Vehicle Engineering
Recumbents.com
Aerohead's post ecomodder
Car Aerodynamics
Diffuser
(read for front/rear impact on underbody drag) and ground effect
Wing and Aerofoil
Maxing out tire pressure
Drag Coefficient - Cd/Cx
Wikipedia listing
Daox CdA listing from ecomodder
Not aero
Driving tips (some usefull A/T tips)
Pulse and glide explained with MPG results
Autospeed articles
As for Autospeed aero articles, I had read a few cool ones (VG experiments, wool tuft testing, airflow test):
Vortex:
http://autospeed.drive.com.au/cms/A_3061/article.html
http://autospeed.drive.com.au/A_3060/cms/article.html
http://www.autospeed.com/A_3059/cms/article.html
http://www.autospeed.com/A_3058/cms/article.html
Aero testing:
http://autospeed.drive.com.au/cms/A_108676/article.html
http://autospeed.drive.com.au/A_108675/cms/article.html
http://autospeed.drive.com.au/A_108674/cms/article.html
http://autospeed.drive.com.au/A_108656/cms/article.html
Aerodynamics:
http://autospeed.drive.com.au/cms/A_107773/article.html
http://www.recumbents.com/car_aerodynamics
http://www.edmunds.com/advice/specia...4/article.html
http://www.ibsinger.com/gallery.htm?...&galleryId=768
Under car airflow (Prius +5MPG):
http://autospeed.drive.com.au/cms/A_2456/article.html
http://autospeed.drive.com.au/cms/A_2455/article.html
Undertrays spoilers and bonnet vents
http://autospeed.drive.com.au/cms/A_2162/article.html
http://autospeed.drive.com.au/cms/A_2160/article.html
http://autospeed.drive.com.au/cms/A_2159/article.html
Wiper blade deflector for noise
http://autospeed.drive.com.au/cms/A_2445/article.html
