Well...I "collected" one on the road headed out to LA and it dawned on me that it could possibly be cut in half (from tip to bottom) and used fer front tire air deflectors. I did return the traffic cone back into the wild along with some of the other one that had congregated at the side of the road looking fer their buddy...
Seeing that I have a ton of miles left to go, I figured I'd ask the question (after doing some searching and seeing that no one else seemed to have mentioned it before) and see how viable it might be instead of using trash cans or other plastic bins cut in half fer that purpose.
I've pulled the extended air dam off fer city driving and will be putting it back on when I head up to northern California tomorrow. I think I'll use a 4" gap instead of the 2" gap I had before...
I can sort of validate the front air deflectors with a bicycle wheel. If you spin them and then put a stream of air directly at it...the wheel/tire will slow down. Now put a deflector in front of the tire and you can see how that will reduce the amount of air friction on the tire/wheel combo.
