Takin' the Vortekz plunge - Page 4 - Fuelly Forums
Old 03-04-2008, 11:35 AM   #31
cfg83's Avatar
zef95 -
Originally Posted by zef95 View Post
http://www.autospeed.com/A_108676/cms/article.html
Here's the section when they tested a MB wagon:
The hatch window of the MB is even more slanted than my 9-5, and it doesn't do squat for aero, it seems. There is one term, though, that I'm unfamiliar with; what is meant by "suction peak?"
What I noticed was the big effect the side view mirrors have :
http://us1.webpublications.com.au/st...08676_15lo.jpg
Attachment 1219
That looks like a big justification for a side-view mirror downsize/delete.
Old 03-04-2008, 11:44 AM   #32
Yes but they also widen the forebody there to a certain extent and possibly allow flow to come in at more of an angle behind. Also have to be careful messing with mirrors in that a smaller mirror with a fully blended root, can in fact cause more drag than a larger mirror out on a bit of a neck. That was something that turned up in the '08 Caravan redesign, think it's mentioned on the allpar site.
Old 03-04-2008, 12:00 PM   #33
cfg83's Avatar
RoadWarrior -
Thanks. I am in the middle of downsizing, and I will be using this :
Blackburn Multi Mirror
http://www.rei.com/OM/style/736837?c...1-000423c27407
Attachment 1220
This might have the "root" problem you are talking about. What is good is that it should be easy to tuff-test. I will keep my passenger side mirror stock and compare the two. If it fails, then I can swap it out with other (flush half-conical?!?!?!) mirrors and test accordingly.
Happy Birthday Jared :) Matt Timion General Discussion (Off-Topic) 3 05-29-2007 06:06 PM
