Surface radiators - Fuelly Forums
Old 06-29-2010, 08:02 PM   #1
Just mount the radiator in the back like an old renault.
Old 01-19-2011, 06:49 AM   #2
Wobblybob's Avatar
Re: Surface radiators
How about making an aluminum belly pan/surface radiator?
Because it's hidden under the car aesthetics wouldn't be that critical. Several possibilities come to mind:
- An aluminum skin with aluminum tubing bonded (mechanically and thermally) to the upper surface with coolant running through the tubing.
- Aluminum flat panel heat exchanger material, if it could be found.
- Exposed rectangular aluminum tubing (maybe 1/2" x 2") which serves both as a frame to support an ordinary coroplast belly pan and a surface radiator.
Certainly the entire belly pan wouldn't need to be a radiator so you could position the radiator portion where it wouldn't have to be bent or notched and where there would be less chance of damage from stones, etc. kicking up from the tires. Maybe a strip down the middle of the car, or crossways in front of the front wheels?
Wobblybob is offline   Reply With Quote
VX head on DX engine? jasonty General Maintenance and Repair 12 02-18-2009 07:11 AM
Alternative to roof rack removal philp100 Aerodynamics 6 05-29-2008 04:46 PM
WTB HX or VX wheels S1K Wanted to Buy 2 04-28-2008 05:54 AM
Lighter Flywheel for Manual Transmission? cfg83 General Maintenance and Repair 24 12-21-2006 10:55 PM
New Saturn hatchback kickflipjr General Discussion (Off-Topic) 6 10-07-2006 12:04 PM
