Stubby antenna vs. long antenna? - Fuelly Forums
Old 09-20-2006, 07:58 PM   #1
How is the reception on a stubby antenna, and is there a huge benefit aero wise to getting the original shorter? smaller?
ketel0ne is offline   Reply With Quote
Old 09-20-2006, 07:59 PM   #2
tomauto's Avatar
Send a message via AIM to tomauto Send a message via MSN to tomauto Send a message via Yahoo to tomauto
I have my antenna as far down as it can go if that means anything to you, the reception shouldn't be any worse...
Current Stable
tomauto is offline   Reply With Quote
Old 09-20-2006, 09:05 PM   #3
kickflipjr's Avatar
stubby antenni don't pick up am stations good. Aero benifits? way too small to worry about.
2008 EPA adjusted:
Old 09-20-2006, 09:59 PM   #4
tomauto's Avatar
aero benefits...
I don't agree with that statement all that much. When I see anntena flush mounted against new cars, it leads me to think that there was some interference, and VW always had the swirl going up their antenna because it (reduced drag)....i'd say every count of drag is worth something.
Current Stable
Old 09-22-2006, 02:19 AM   #5
If your worried about it , go with a stick-on window antenna instead.
No aero issue then...
Old 09-23-2006, 01:40 PM   #6
Originally Posted by tomauto
aero benefits...
I believe antennaes normally do have a significant amount of drag, if you've ever watched, they'll bend back quite a bit at highspeed. If you try to bend them back with your hand that far you'll notice it's actually quite a large amount of force.
The design of antennes is very inneficient, i don't understand why they don't use a more aerodynamic shape, such as the teardrop. Circles actually have a drag Cd of .5!!
The spiral winding I believe is more designed to get rid of the hispeed whistle noise more than to cut down on drag.
Old 09-23-2006, 04:12 PM   #7
|V3|2D
thisisntjared's Avatar
most antennas are less than 1cm thick... even the stubby ones. i doubt the effect the car too much.
that said i have an antenna block off plate on my hatch, and let me tell you: the reception is horrible
Basic Stats poorboymeyer Fuelly Web Support and Community News 2 09-22-2009 09:19 AM
