Spring loaded segmented air dam? - Fuelly Forums
Old 04-09-2009, 05:44 AM   #1
When I read about optimal air dam heights I cringe because of all the frost heaving around here. One spring I knew someone who would bottom out his DeLorean consistently. Anyhow, what if the air damn were made in sections, each with a hinge and a spring that allowed it to swivel up if a bump were encountered. I figure using flexible air dam materials it would be much harder to get the desired resistance level than using a spring. Also, segments mean replacing worn out sections would be easier. So, sanity check: does this idea have any obvious flaws? Thanks.
co de pen den cy
Function: noun
Date: 1979
Old 04-09-2009, 06:03 AM   #2
You could also make the air dam extend forward at an angle to get more of a ramp pushing air up effect I guess.
Hmmm...end on collisions wouldn't play nice with that as it swiveled up. Drat. Well, it would be ugly anyway!
co de pen den cy
Function: noun
Date: 1979
Old 04-09-2009, 06:16 AM   #3
Little wheels on the bottom might help with scraping, but it's probably overkill.
co de pen den cy
Function: noun
Date: 1979
Old 04-09-2009, 07:12 AM   #4
GasSavers_BEEF's Avatar
I haven't had much luck with my airdam. I extended it (probably too much) and saw no gain from it (there may have been a change but not much).
I recently trimmed it down because of scraping. I have heard that a belly pan would help more than an airdam. I was going to do that but the time involved kept me from doing it.
Old 04-09-2009, 07:13 AM   #5
I've pretty much rejected a belly pan for difficulty reasons. That's one modification my mechanic actually thinks is worth doing. Maybe I'll take another look.
co de pen den cy
Function: noun
Date: 1979
Old 04-09-2009, 07:24 AM   #6
I had actually gotten a piece of coroplast to do it with. after looking at my car and how I was going to have to get my car in the air, I scrapped the idea. I don't have a lift or a friend with one. one of my friends is planning on getting one in a few years.
the material of choice around here is coroplast but one user used tub surround from lowes. I tought that was ingenious. he has a cavalier and his user name is phlease (I think). he is getting really good mileage. he is my hero (I have a few).
I did think about getting some jackstands but I am cheap.
Old 04-09-2009, 07:28 AM   #7
Wow. That IS cheap. I'm just too lazy.
co de pen den cy
Function: noun
Date: 1979
Old 04-09-2009, 07:42 AM   #8
maybe lazy would be a better description. I do have two ramps made of plastic that I use to change oil.
I would really just be getting the jack stands to do the belly pan with. I never think about it when I am out and I don't want to make a special trip for them. I also have issues with paying 20-40 dollars (can't remember what they cost) to put on a $20 modification on my car.
Old 04-09-2009, 07:55 AM   #9
How are those plastic ramps? I have some bright yellow metal ones. Have some plastic fore-ramps that help with lower clearance vehicles (got 'em for free - left behind by a former renter). I'm always nervous driving up those things.
co de pen den cy
Function: noun
Date: 1979
Old 04-09-2009, 08:35 AM   #10
Send a message via AIM to jeep45238
Look at the front of most GM cars. Almost all of them have a vertical plastic "air dam" that's spring loaded like you're describing.
Democracy is two wolves and a sheep deciding what to have for dinner. Liberty is a well armed sheep contesting that decision.
jeep45238 is offline   Reply With Quote
Using a GPS for fuel economy ketel0ne General Fuel Topics 30 05-04-2009 11:59 AM
Question about soloenoid. omgwtfbyobbq General Maintenance and Repair 12 12-28-2006 09:42 PM
Looking for Insight wheel numbers GasSavers_Ryland General Maintenance and Repair 3 07-08-2006 10:02 PM
