Originally Posted by MetroMPG
Tin foil taped/pressed in the area that will serve as the base of the object being created makes a decent non-reactive "release agent", and will protect the paint.
Skip the foil - go for plastic wrap
That was an alternative plastic film release suggested for vacuum bagging - it should work as a substitute for a mold release.
I second the vote for microballoons - very cool stuff - it also adds a lattice matrix to the resin structure (making it stronger). Just remember how much resin you originally started with as the MBs will increase the volume AND don't mix with the hardener - mix in the MBs then add hardener. I'm getting ahead of myself though :P
I think that foam will melt if you expose it directly to polyester resins (you may have better luck with epoxy resin though - but that's more expensive). A cheap way to fill in holes after it has been shaped is wax - a nice thick wax (a mold release paste wax would be best
That could, in theory, protect the foam too.
Lastly, to make your part a bit smoother -- before layup, coat with some form of gellcoat. A thick resin (microballons won't work here) first - and then use thin resin for your glass. Or, mix a thickening agent (like fumed silica - cabosil OR a fairing filler) to make the resin thixotropic.
Once done, you can use a fairing putty to help get a very smooth part that will paint nicely.
SmoothOn is a great Supplier (sometimes a bit expensive, you need to price it out
I've used US Composites myself, and our HPV team has used them for the past three years because of cost and they are a somewhat local company (Ha! I just noticed Jan mentioned them too :P)
I'm just throwing a whole bunch of stuff out there - the route (and there's more) you take will be dictated by budget, availability (most of the stuff you can get online though) and how ambitious you want to be with the project
Lastly - that is a GREAT idea
Now I have more to think about :P
