Spoilers - Fuelly Forums
Old 05-11-2006, 09:38 AM   #1
Spoilers
Howdy folks
I came across an article here in this site about the usage of spoilers and their effect to fuel saving. I would like to get some ideas and instructions from those of you who have builte their own.
I just do not want to buy those "fast and furious" crap sold in the market but something effective.
Any advice most welcomed...
All the best
Murat is offline   Reply With Quote
Old 05-11-2006, 10:04 AM   #2
Spoilers
There are 2 types:
"Chin" spoilers at the front reduce areo drag under the car. They do help save gas. However, low chin spoilers frequently get broken off on speed bumps and curbs.
"Tail" spoilers are used to produce down force, pressing tires against the pavement for better cornering at high speeds. Around town, the don't add much down force, but the drag reduces your mileage.
Spoilers don't help much, imho. Aero modifications that do increase mileage are: tonneau covers (for trucks) belly pans and wheel skirts.
Old 05-11-2006, 10:11 AM   #3
I see
Well I went to this workshop which produces plexiglass shower cabins. I asked him if he could cover the bottom of my car and other information. He told me he would do so and the weight added would be around 25 kgs (55lbs) (car: 2006 Hyundai Getz 1.4 16V)
I guess I can compensate that weight gain's effect by lowering the car and decreasing its profile...??
Old 05-11-2006, 11:48 AM   #4
|V3|2D
thisisntjared's Avatar
that weight seems to be too
that weight seems to be too much. however spoilers can help with the coefficietn of drag! he is correct about the article!
there are some really good links from this site in some threads concerning aerodynamics.
lowering the car will help as it removes some of the frontal area from the tires.
Old 05-12-2006, 10:50 AM   #5
Right,
I thought so. Well the plexi underbody cover is of 5mm (approx 1/5 inches) it can be made of thinner plexi as well but I feared it could be too frail against rocks and bottomoing out at speed bumps or such.
The workshop owner said 2mm (approx 1/11 inches) would suffice and it would weigh like less than half that (20lbs or so)
I dunno...
Whhoooppsss forgot to add : could you guide me to some of the links if I would not be of too much trouble ?
Old 05-12-2006, 12:36 PM   #6
http://www.gassavers.org/forum_topic/belly_pan_installation_honda_del_sol.html
That's the one by dan, cheap and easy,
Old 05-12-2006, 12:44 PM   #7
|V3|2D
these are two good ones for
these are two good ones for basic starting knowledge.
http://www.tfd.chalmers.se/~lelo/rvad/reports/rva2002_gr11_contribution-to-drag.pdf
http://www.tfd.chalmers.se/~lelo/rvad/reports/rva2002_gr10_drag-reducing.pdf
Old 05-13-2006, 12:04 PM   #8
Re: Saw the topic
Dan did a good job. However, I am a bit of a "tid,ness freak"... Besides, my car is only 2 mo. old and I'd rather stick to a little more expensive but neat thing. I guess a 1mm plexi sheet should do the trick if corrugated plastic and duct tape can do the trick...
I will go using cord lock strips to fix the plexi sheets to areas suitable thru eyeholes I will drill on the fly...
Will submit some pics soon as I get the project rolling. BTW, don't you folks ever fear the cat? It heats up to enormous temperatures and could burn the stuff you place close...
Old 05-13-2006, 12:39 PM   #9
Re: these are two good ones for
Saved the pdf' s right away !! Thanks a lot... Gonna design and build wheel spoilers with splitters and deflectors... The car already has rear wheel spoilers and a tiny air dam in the front but guess I need to enhance them in a stylish way... So I'm gonna hit the foam block with my xacto and sandpaper !!
Old 05-14-2006, 08:02 PM   #10
GasSavers_Ryland's Avatar
for a belly pan, and even
for a belly pan, and even wheel covers, I would searusly think about something like polycarbinate because it's going to be less likely to shatter, it's what's used for safty glasses, or try air plane fabric and paint, you should be able to attach either one of these with metal edges that are pined on, or buttened on, or held on with small bolts and "T" nuts.
Reporting capabilities via SMS? hidesertmlb Fuelly Web Support and Community News 4 09-02-2008 12:02 AM
Where to get parts? What parts do we need? Matt Timion Electric and Solar powered 11 09-19-2005 08:37 PM
Concerning methods of measurement Flatland2D General Fuel Topics 3 09-17-2005 10:04 AM
