Since carbon fiber is soooo expensive... - Fuelly Forums
Old 08-24-2009, 08:42 PM   #1
BamZipPow's Avatar
Send a message via AIM to BamZipPow
NASCAR is using Tegris fer the front splitter. Seems it's about 70% as strong as CF and about 1/10th the cost...
I wonder if it would be feasible to make undertray and other aerodynamic panels from this stuff...
Seems to hold up pretty well in collisions, too!
Link...
Tegris is composed of polypropylene threads fused together in successive layers. The patented process starts with a polypropylene structure co-extruded as a film, which is then slit into tapes and highly drawn to create a stiff, strong core. The tape yarn is woven into a fabric, and successive fabric layers are pressed together to create a single piece using thermoforming. The outside layers fuse together, playing the same role that the epoxy or resin plays in a carbon-fiber composite, while the core provides the structural strength. Layers are stacked and pressed together at very high pressure, then cut using water jets (like the one MindTribe helped develop for Flow International). The NASCAR splitter uses 100 layers of the fabric.
BamZipPow is offline   Reply With Quote
Old 08-24-2009, 09:39 PM   #2
Great link and info as well.
Is this stuff similar to DuPont's PP product TYVEK?
I had an envelope made from that stuff and never found anyone who could tear it open without using some sort of mechanical device.
Any idea how it compares for weight?
Pete.
GasSavers_Pete is offline   Reply With Quote
Old 08-24-2009, 11:46 PM   #3
BamZipPow's Avatar
Pete.
I had a Tyvek car cover...it's strong but it didn't weather very well in sunlight and after a year. I don't think Tyvek has the same strength capabilities per layer than Tegris does...
Old 08-27-2009, 09:51 AM   #4
Carbon Fiber isnt that expensive if you have ever had experience making things out of fiberglass you should be able to make things out of carbon fiber as well. http://www.fiberglasssupply.com/Prod...nd_kevlar.html just order what you need. The resin from your local auto parts stores made for fiberglass will work just fine with this.
OldCorolla is offline   Reply With Quote
Old 08-27-2009, 11:51 AM   #5
Site Team
I believe Tyvek is usually a fiber. The idea of interwoven oriented PP tapes will add a lot of strength compared to "bland" PP.
However, it seems that you'd either have to live with flat sheets, or purchase some fancy thermoforming equipment to make it into a desired shape (although I'd suspect you could bend it slightly if you needed to)...
-BC
Old 08-31-2009, 03:27 PM   #6
this tranny might fit, if not just cut off a leg or something
zero_gravity is offline   Reply With Quote
Old 09-14-2009, 11:41 AM   #7
Seems like you would need quite the infrastructure to manufacture things using Tegris.
If you're worried about the cost of CF, look to get basalt fiber. Stronger than FG, cheaper than CF.
Evidently CF is so "cheap" these days (I guess it's a relative thing), basalt fiber cloth is not competitive.
Old 09-17-2009, 11:09 AM   #8
You mean a big oven and a big metal mold! My wife would get mad if she saw that in my back yard.
GasSavers_Merc is offline   Reply With Quote
Mandatory EOC red91sit General Fuel Topics 4 06-07-2008 07:55 PM
Hey Rabby Introduce Yourself - New member Welcome 1 05-21-2008 11:15 AM
Hello from WI 204snic Introduce Yourself - New member Welcome 7 11-16-2007 10:08 AM
Good LRR review in Europe for the new Hankook Optimo K715 Spule 4 General Maintenance and Repair 6 07-28-2007 04:24 AM
krousdb & xcel win MPG rally at Tour de Sol MetroMPG General Fuel Topics 32 05-19-2006 03:12 AM
