Rear Wheel Skirts That Bulge (issue) - Fuelly Forums
Old 05-06-2006, 09:03 AM   #1
I'll have to get pictures later, but the problem is pretty simple: my rear wheels are out far enough that I can't make a rear skirt that runs flush with the body of the car.
So, I see that I have two options:
1. Make one that doesn't go all the way down
2. Make one that bulges out a little bit and goes all the way down.
Whatcha think? I'll snap some good picture later in the day hopefully.
Old 05-06-2006, 10:19 AM   #2
800 ? 800: true);
Old 05-06-2006, 11:03 AM   #3
Matt Timion's Avatar
Ah yes... the bulge issue. I
I think both solutions are good ones for this problem. I've actually considered doing both at one time or another.
I'll probably end up making one that goes all of the way down and just bulges out past the tires for the ultra geek effect.
Old 05-06-2006, 12:49 PM   #4
zpiloto's Avatar
I think you'll need to go
I think you'll need to go all the way down for increase FE. I have the same problem and tried skirts that came down to the bulge and saw no effect on the FE. My driving is mixed, hardly ever get over 60 and most of the time it's around 30-40 MPH averaging about 30-35 MPH for a tank of gas.
Old 05-06-2006, 01:08 PM   #5
down
The bottom of the tire is not moving through the air - ground speed is 0 so you don't have to cover it. The upper half of the tire is moving at twice the ground speed and needs to be covered.
Old 05-06-2006, 03:25 PM   #6
Re: down
Excellent point -- kinda like how tornadoes will destroy one house and the house next door is left untouched: there's a fast side as it moves and a slow side. I also see some camber issues (I think I'd run into the same problem). I'd experiment with the top half idea -- first though, jack up each side of the car and see if the top of the wheel pushes out at the top in any form during suspension operation. All hope is not lost.
Old 05-06-2006, 03:32 PM   #7
GasSavers_bugmenot's Avatar
Re: down
if ground = 0 and upper = 2 x ground (0)
you still have 0
GasSavers_bugmenot is offline   Reply With Quote
Old 05-06-2006, 04:10 PM   #8
Re: Rear Wheel Skirts That Bulge (issue)
i think the full ones looks better. and even though the very bottom of the tire may not be moving relative to the ground, the wheel arch *is* moving through the air at full speed, so the further down you streamline it, the better.
mine bulge out a bit - see the photo in my DIY of the aluminum strip i attached to the back side of the skirt to get an idea of the shape i had to use.
you could cheat and stick a set of rear mudflaps on - that's what my skirts attach to (which reduces the amount of "bulge" required to clear the tire).
Old 05-06-2006, 05:18 PM   #9
If you mean enhanced handling through curves issue, yes, you see that.
Old 05-06-2006, 05:19 PM   #10
Agreed, this is why I will prolly go for them. The insight looks like it bulges, yeah?
Prolly hella expensive jdm ****,
« - | Spoilers »
AC on and fuel milage tdisr General Fuel Topics 5 05-24-2009 01:25 AM
Higher Speeds MetroMPG Experiments, Modifications and DIY 9 05-25-2006 02:23 PM
Dilemma concerning front sway bar on n600 Matt Timion General Maintenance and Repair 3 05-24-2006 10:37 AM
TSB-Technical Service Bulletin Compaq888 General Maintenance and Repair 5 03-20-2006 10:12 AM
Concerning methods of measurement Flatland2D General Fuel Topics 3 09-17-2005 11:04 AM
