Rear Wheel Skirts That Bulge (issue) - Page 2 - Fuelly Forums
Old 05-06-2006, 06:09 PM   #11
cover
if ground = 0 and upper = 2 x ground (0)
you still have 0
The Ground speed is the speed over the ground - the bottom of the tire is at 0 mph unless it is slipping and the top is twice the Ground speed moving forward - the center of the tire is at ground speed.
Old 05-06-2006, 08:20 PM   #12
Re: Quote:i think the full ones
Originally Posted by SVOboy
Prolly hella expensive jdm ****,
mine are $5 aftermarket jobbies. pancake flat, no fancy molded stuff.
i don't think the insight has any flare to their skirts. they're pretty flat straight across. remember, the insight's rear track is narrower than the front, so that helps with the skirt clearance issue.
Old 05-07-2006, 09:48 AM   #13
GasSavers_bugmenot's Avatar
Re: cover
you still have 0
right
bottom of tire 0
center/hub 1
top of tire 2 , or twice the center/hub speed (gound speed, not twice the bottom of tire speed)
GasSavers_bugmenot is offline   Reply With Quote
Old 05-08-2006, 12:48 PM   #14
Why not buy a aftermarket
Why not buy a aftermarket wheel with more backspacing?
kozaz is offline   Reply With Quote
Old 05-08-2006, 12:53 PM   #15
Matt Timion's Avatar
Re: Why not buy a aftermarket
I think most of the aftermarket wheels are wider than stock, not skinnier.
Does anyone know what the bolt pattern is on teh honda insights? I they their wheels are really narrow.
Old 05-08-2006, 03:32 PM   #16
krousdb's Avatar
Why would they be any different then other 4 lug Honda wheels, 4x100mm.
Old 05-08-2006, 04:24 PM   #17
There happen to be 4x114.3 things out there in the honda/acura lineup,
Old 05-08-2006, 04:51 PM   #18
krousdb's Avatar
Re: Quote:Why would they be any
The easiest thing to do is go to tirerack and choose wheels for an Insight. It will tell you the bolt pattern. im toooo lazy to look. Speaking of Insights, I will be driving one from Wed thru Sat. Hypermiling heaven!
Old 05-08-2006, 04:57 PM   #19
I'm pretty sure it's 4x100,
I'm pretty sure it's 4x100, I'm just giving you a hard time about the 96-97 itr.
Old 05-08-2006, 11:27 PM   #20
Honda actually has a few 5-lug wheels out there now adays. Maybe that's acura... can't remember.
« - | Spoilers »
AC on and fuel milage tdisr General Fuel Topics 5 05-24-2009 01:25 AM
Higher Speeds MetroMPG Experiments, Modifications and DIY 9 05-25-2006 02:23 PM
Dilemma concerning front sway bar on n600 Matt Timion General Maintenance and Repair 3 05-24-2006 10:37 AM
TSB-Technical Service Bulletin Compaq888 General Maintenance and Repair 5 03-20-2006 10:12 AM
Concerning methods of measurement Flatland2D General Fuel Topics 3 09-17-2005 11:04 AM
