Rear spoilers........ - Page 4 - Fuelly Forums
Old 07-28-2006, 06:10 AM   #31
I think wood is ideal for a lip extension (flexible for the size you'll need, relatively easy to work/shape).
Maybe start with a piece of quarter-round trim, shape, shave & sand it to your liking, then coat it with polyester fiberglass resin to weatherproof it. Sand & paint. Install.
Have you verified you've got attached flow at the trailing edge of the trunk without the OEM wing?
There's a small chance that the OEM "wing" could have been good for aero if the deck lid is a bit too low to attain reattachment. The upper wing surface may have been where that was happening.
Before investing the effort in the lip spoiler, I'd want to know for sure.
Old 07-28-2006, 07:51 AM   #32
Correction: I was wrong with "quarter round". The shape I was thinking of is the same as the bottom 2 in this image:
Not sure what that's called.
Old 07-28-2006, 09:55 AM   #33
GasSavers_brick's Avatar
Haven't done it yet, but you're absolutely right. I can't take video, but I did find a way to rig my digital camera and laptop to take stills automatically while I'm doing a test run with tufts on the lid. If I don't have attached flow I'll put the factory wing/spoiler/whatever back and re-test. Maybe I'll get around to it tomorrow?
'07 Toyota Prius
Old 07-28-2006, 09:59 AM   #34
Do you have holes in your poor hood without the factory wing on there?
Old 07-28-2006, 06:36 PM   #35
Nope, I installed plugs made from painted carriage bolts sealed with rubber fender washers. It's not ideal but it works well.
'07 Toyota Prius
Old 07-28-2006, 08:32 PM   #36
lovemysan's Avatar
<IMG style="; WIDTH: expression(this.width > 800 ? 800: true); max-width: 800px" alt="" src="http://www.oldershaws.com/images/profile1.jpeg" border=0>
Thats cove round I believe
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 07-29-2006, 08:52 AM   #37
ZugyNA's Avatar
From the MiniCooper science fair project: (pdf abstract)
"From research, I found that most of the drag on the car is related to how the air comes off the back of the
car. This separated flow creates a partial vacuum that is responsible for most of the drag. By creating
attachments, I found I could make that area of separated flow smaller. A good visualization of this is the
process of narrowing the wake of a boat. My first attachment design consisted of two vertical wings
attached at the back sides of the car and curved inward, which narrowed the flow.
My second design was
one wing down the center. This resulted in increasing the drag instead of lowering it. Several other
designs were tested, but they had little effect on the drag. The results I collected in the wind tunnel
supported the results I got from testing the set up on the car. My first attachment design was the most
successful and it reduced the total drag by 12.5%."
Old 07-29-2006, 10:19 AM   #38
AKA a partial boattail. Neat. Too bad no pics in the PDF.
Also I suspect the author meant "angled inward" instead of "curved inward". But I could be wrong.
Old 07-29-2006, 11:48 AM   #39
ZugyNA's Avatar
But these verticals seem to be pointing outward?
http://www.max-mpg.com/html/tech/main.htm
Probably has to do with the shape of the body work in front of it?
Looks like they act like LARGE vortex generators?
Bunch of small vgs or 2-3 large ones (wings)?
A suggestion to improve the site buttersnz Fuelly Web Support and Community News 4 08-19-2013 10:25 AM
iphone mobile broken RicksCafe Fuelly Web Support and Community News 2 01-22-2012 07:02 AM
Multiple fuel ups - same date pdqford Fuelly Web Support and Community News 5 08-17-2011 02:04 PM
Nissan Altima REAR wind diffuser/belly Compaq888 General Fuel Topics 36 02-08-2006 01:10 PM
Where to get parts? What parts do we need? Matt Timion Electric and Solar powered 11 09-19-2005 09:37 PM
