Hello me -
Originally Posted by cfg83
theclencher -
(writing about wiper arms without wipers damaging window glass)
That's why I haven't done it. Hmmmmmmm,  , but maybe I could remove the wiper fuse and thereby disable the wipers! To re-install, turn off car, insert fuse, turn on car  !
I just checked. My (25 Amp) wiper fuse is inside my car. I could make it even more slick by connecting a 25 Amp car switch wired into where the fuse is inserted. That way, I wouldn't even have to remove the panel to activate the wipers. Still have to be carefull, though. Maybe a "failsafe" covered switch to look even slicker.
Would a "switch" harm the function of the fuse panel? I ask because accidently turning on the switch would be the same as inserting a fuse into the panel while the car is running.
With the wiper/fuse switch option, I would be stuck with the wiper arms. At a minimum, I would cover the ends with vacuum plugs to protect the glass.
Hmmmmmmm. How about this? I *could* devise some sort of "aero-wiper-cowl" to cover the arms, and use the wiper blade connector to fasten them on. Ideally, the air would flow over the cowl in a clean manner. Worst case would be that the air stream gets under the cowl and pulls up the wiper arm. The goal is that the spring in the wiper arm would be strong enough to keep the cowl snug on the freeway. The definition of "snug" in this case would be maybe 80 MPH or less.
Random thought. Is this an opportunity for Vortex Generators on the cowls?
I am imagining "green leafy" cowl shapes in my head (long/thin, tapering on each end), but I am sure something else would be better. Maybe just black rubbery plastic cut and fitted to take advantage of where the wiper arm lies on the cusp of the hood/window.
