Question about belly pan - Fuelly Forums
Old 07-31-2007, 04:05 PM   #1
Send a message via AIM to Dave1215
I've heard that duct tape is pretty weak at holding up cardboard so i've been thinking...If I got a decently thick slab of cardboard and screwed it under the car for a belly pan for a temporary 900 mile round trip from the los angeles area to san francisco do you think it would hold up? I've been looking for coroplast but I guess i'm kinda out of luck since i'm leaving thursday...any input from anyone for this idea? Any help would be appreciated thanks!
Best Tank: 54.43 mpg
Dave1215 is offline   Reply With Quote
Old 07-31-2007, 04:18 PM   #2
Hockey4mnhs's Avatar
idk about that holding up but if thats all you have to work with then i would go for it for at least the trip. if it falls of you might get a little of a gain from when it was on there.
Old 07-31-2007, 04:34 PM   #3
cfg83's Avatar
Dave1215 -
I think there is a sign/banner shop on San Gabriel Blvd, north of the intersection to Las Tunas. I have been meaning to go in there, but have not got around to it.
... Hi ho, hi ho, it's off to yahoo maps I go ... here it is :
Special Signs
(626) 285-8870
specialsigns.net
115 N San Gabriel Blvd
San Gabriel, CA 91775
If you call them, you can find out if they sell coroplast.
Old 07-31-2007, 04:37 PM   #4
yahooo!!!!! thank you cfg83 they do have it i'm goin to go pick up a sheet...how much do you think i'll need? they have a 4'x8' white sheet with 1/8th inch thickness for $28 would that work for the belly pan and grille block?
Old 07-31-2007, 04:47 PM   #5
cfg83's Avatar
Dave1215 -
I haven't done a belly pan on my car. You may not need to do the whole bottom. It depends on what other's have done to their civics on GasSavers.
$28 for a 4'x8' sounds reasonable to me.
Old 07-31-2007, 04:58 PM   #6
cfg83's Avatar
Dave1215 -
Here is one example for a Del Sol :
Belly Pan Installation, Honda Del Sol
http://www.gassavers.org/showthread.php?t=671
It's the same white coroplast, and 4mm thick sounds like a match to the 1/8" thick. It looks like krousdb used 8'x8' total, but I don't think you have to make it as detailed as krousdb.
At least not yet ,
Old 07-31-2007, 08:13 PM   #7
S&W plastics has what you need when your Coroplast goes byebye. They have ABS, expanded PVC, etc. There's one in Ontario, one in San Berdoo, probably others
Everyone wants to live inTheory. Because everything works THERE.
mustngr is offline   Reply With Quote
Add driver to car already in garage, for shared car ssquid Fuelly Web Support and Community News 1 01-05-2013 02:10 PM
Civic VX miss under load oh95vx General Maintenance and Repair 54 07-21-2011 08:57 PM
Idle speed control valve zpiloto General Fuel Topics 19 03-01-2007 03:16 PM
LRR snow tires? GasSavers_Ryland General Fuel Topics 4 11-14-2006 02:40 AM
IAT Sensor Mod (Resistor Mod) SVOboy General Fuel Topics 28 10-17-2005 07:08 PM
