Proper shape of a belly pan - Fuelly Forums
Old 04-27-2007, 07:35 PM   #1
I'm going to start making my belly pan. I have two choices as to the shape of it. My truck's exhaust system extends a couple of inches below the level of the frame rails so I can either bow the belly pan to enclose it or cut a channel into the sheet metal in the shape of the exhaust and cat converter. Would it matter if the belly pan wasn't flat? Also, would 22 gauge steel too thin?
jdham137 is offline   Reply With Quote
Old 04-27-2007, 09:52 PM   #2
lovemysan's Avatar
IMHO 22 gauge steel is too heavy. A 28-30 gauge steel would be more ideal I think. The only place I would use steel in a belly pan would be the first 4 feet under the front. That area takes a beating. The most annoying part of using sheet metal is the waves formed by screws shifting while being driven in. A good frame system greatly eliminates this.
I used aluminum sheet bought in a coil from Home depot.
As for your question. Weigh the pros and cons. I'd prolly bow around it. I did that on my exhaust. You don't want to go to extreme time consuming measures, time is money. Get in there and get it done as quick and neatly as possible. You don't want to stagnate and not finish.
Good luck and take pictures. I drove my 96 hardbody for 6 years so I'm rooting for ya
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 04-27-2007, 09:56 PM   #3
lovemysan's Avatar
Thought I'd mention why I don't really like the steel. Because it will add a lot of weight. Probly 150-200lbs. I have nearly 100lbs under my saturn and thats using an extruded aluminum frame, aluminum flat coil, and coroplast.
Don't forget that the engine cooling air will need an exit and the catalytic convertor can be the hottest part of the exhaust. Also get a fire extinguisher just to be safe.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 04-29-2007, 09:20 AM   #4
Lovemysan,
Thanks for the info. I went to HD and bought a 20" by 50' roll of aluminum flashing. 20" was the widest they had but I can still use it. I saw your pan in the archives, what a work of art! I hope mine looks as good.
John David
Old 04-29-2007, 11:36 AM   #5
If you build some covers out of the aluminum and then find that they are noisy or that they flutter, I have thought that maybe putting a thin layer of Great Stuff foam would help deaden the sound and dampen vibration.
I had no idea that they made 20" wide flashing. I need to think about using that for my next project instead of coroplast.
Add driver to car already in garage, for shared car ssquid Fuelly Web Support and Community News 1 01-05-2013 02:10 PM
Joint Membership with GasBuddy? Badams Fuelly Web Support and Community News 2 07-02-2011 12:14 AM
gas mileage improvements GasSavers_gashog General Fuel Topics 1 09-21-2006 06:13 PM
IAT Sensor Mod (Resistor Mod) SVOboy General Fuel Topics 28 10-17-2005 07:08 PM
Got my headers today & question 'bout crank scrappers b1gmoose General Fuel Topics 8 10-08-2005 10:49 PM
