Pickup tailgate up or down - SAE Studied - Fuelly Forums
Old 08-29-2007, 07:27 AM   #1
bones33's Avatar
See this link if this iterests you. http://ecow.engr.wisc.edu/cgi-bin/ge...hi1/pickup.pdf
Results: Keep it up. Tonneaus MAY help.
bones33 is offline   Reply With Quote
Old 08-29-2007, 09:04 AM   #2
MetroMPG's Avatar
Great find! Thanks.
Old 08-30-2007, 09:30 AM   #3
palemelanesian's Avatar
If you look at the tables on page 8, the results are different for crew/extended cab than they are for regular cab / long bed. Ext cab - tailgate up, reg cab long bed - tailgate down.
Old 11-12-2007, 08:06 PM   #4
That was my experience as well, my '86 D-250 did get an improvement with the tailgate removed (std cab) but my '95 club cab did not.
Best I can recommend is do your own experiment, mythbusters is entertainment.
As for it up or down, I never understood this concept.
If up is the answer there is nothing more doing, have a nice day.
But if down is the answer then take it off and install an air mesh gate, saves another 20+ pounds of weight, why leave the stupid thing on?
Old 01-17-2008, 10:14 AM   #5
Agreed, my old 86 standard cab did see an improvement thou I will say I would rather remove the tailgate completely and install a mesh. But on my '95 club cab I am as well if not better off leaving the tailgate in place.
I would further bet it varies from one to the next, you just have to try it and see for yourself, but I do believe either way could work and there is no specific one-size-fits-all solution here.
Old 09-02-2007, 09:43 PM   #6
Snax's Avatar
This report confirms what I suggested in another thread, that there is a specific zone behind the cab after which it makes sense to attempt to establish more laminar flow off the rear of pickups. A longer bed, with far less impact from cab length, will benefit more greatly from aerodynamic aids for this reason. I would argue that if one had a bed length nearly equal to the height of the cab to the bed, it would not make any significant difference, tailgate, mesh, tonneau, or whatever because there is virtually no opportunity to re-establish a laminar flow that close to the cab at anything but the slowest of speeds where the impact is nearly nil.
In short, I think it could be argued that longer beds net better aerodynamic possibilities and shorter beds provide less opportunity for improvement. The length of the cab is relatively insignificant.
LiberalImage.com
I think, therefore I doubt.
Old 09-11-2007, 03:36 PM   #7
I just watched part of the re-run of mythbusters on the pickup tailgates. you may loose .02 cd but if the 80+ lbs tailgate is removed wouldn't the mpg go up some if 100lbs = 1mpg. they didn't factor the weight reduction just focused on air disruption.
ffvben is offline   Reply With Quote
Old 02-02-2008, 04:10 AM   #8
I noticed that too, but my truck weighs something like 3,700 pounds empty and the tailgate itself doesn't weight but maybe 50 to 70 maybe 80 pounds. It's not ueber light but I don't think it weighs 100, I can take it off pretty easily.
Then I have to remove at least 200 pounds to make a difference (400 is more like it), however on a club cab there's always the useless back seat (for some of us), and of course any of an amount of crap we like to carry with us might be best left at home, it can and does add up...
But in and of itself tailgate weight alone is not that substantial, however if you notice an improvement leaving it down then I would recommend removing it entirely and putting in place an air mesh.
Old 09-11-2007, 03:47 PM   #9
I don't think that the weight reduction is worth nearly that much. Especially on something as heavy as a truck.
Old 09-11-2007, 07:46 PM   #10
trebuchet03's Avatar
I thought they recorded empirical data with the tailgate removed... I'm fairly certain that factored in the weight reduction...
And even more especially at steady state -- not accelerating (unless the mass removed from the vehicle was spinning).
11/12
Adding a Tank Size. Shifty54 Fuelly Web Support and Community News 1 04-13-2010 06:07 AM
Things To Look For When Buying A Civic Vx??? panamacolin General Fuel Topics 10 08-15-2008 03:57 PM
Sparrow Electric Car Matt Timion Electric and Solar powered 11 06-27-2006 08:50 PM
