Originally Posted by RningOnFumes
Mythbusters also tackled this issue. Basically, there is a bubble of air that is trapped in the bed causing the airstream to go over it as if there was something there. So tailgate up is best.
Their method was flawed, even the SAE test posted is flawed. There are more variable changes in the different vehicles they used then simply the tailgate on/off or up/down. Why they didn't just use one vehicle I don't know.
Anyway whether it helps or not the best solution is definately a fastback type tonneau which I had planned to make but didn't have $100 to shell out for a snap fastner riveter (anyone have one I can borrow
? ). I was worried if I'd need an underside frame for it and how taut it needed to be, etc, but BBQs idea is the best and come spring I'll probably try that.
That is: Instead of making a full tonnaeu all sides, etc out of fabric, I can use 2x4s and plywood and make wood sides that slide tightly right into the 3 post holes on each side of my bed and have the tonneae snap onto/over that. It'd probably be less pretty, but certainly more sturdy and pretty easy to make. They'll probably look similar to the Ridgeline but bigger on their own and will probably help on their own to keep turbulence off the sides of the truck from affecting the bed. With the longbed, I plan on going a bit more extreme and openning the tailgate and attaching the tonneau to the open gate (and making the sides to match), should help even more. What I'd really like is something I can slide into the openning between the end of the bed and the tailgate so I can make a half height wall or something so hard acceleration won't have stuff sliding off the bed. Maybe I can make this out of wood too.... hmmm...
