Pickup tailgate up or down - SAE Studied - Page 2 - Fuelly Forums
Old 09-11-2007, 08:46 PM   #11
trebuchet03's Avatar
I just watched part of the re-run of mythbusters on the pickup tailgates. you may loose .02 cd but if the 80+ lbs tailgate is removed wouldn't the mpg go up some if 100lbs = 1mpg. they didn't factor the weight reduction just focused on air disruption.
I thought they recorded empirical data with the tailgate removed... I'm fairly certain that factored in the weight reduction...
Originally Posted by SVOboy View Post
I don't think that the weight reduction is worth nearly that much. Especially on something as heavy as a truck.
And even more especially at steady state -- not accelerating (unless the mass removed from the vehicle was spinning).
11/12
Old 09-14-2007, 04:48 PM   #12
soft toneau cover might be the answer , i installed one on a 07 frontier that had to weigh around 20lbs. but I cant stand those big zippers on it,pulling/tugging to get the end zipped up is a pain.
Old 09-14-2007, 11:50 PM   #13
lol or the evil snap kind! even worse...
Old 10-25-2007, 09:53 AM   #14
Does anyone have any figures with respect to truck caps? I know when I removed mine I didn't get kicked around nearly as much but unfortunately I wasn't keeping track of my FE numbers at the time... :$
On the bright side, I do know that with the cap off and the tailgate up I destroy my EPA numbers, old or new...
Matt
autocrash is offline   Reply With Quote
Old 11-07-2007, 04:16 PM   #15
NH Titan's Avatar
I just added a truck cap to my truck. I checked mpg just before and got 17.8 and then right after and got the exact same. My cap is taller than the height of the truck by about 3-5 inches. It is slanted up at about the same rake as the windshield. I was wondering if the non cab high height would effect mpg negatively but it seems like it hasn't.
2001 Chevy Cavalier 2d 5sp Best MPG 43.94
NH Titan is offline   Reply With Quote
Old 11-07-2007, 06:47 PM   #16
It probably has reduced FE compared to a cover that didn't increase the frontal area of the car....
11/12
Old 11-12-2007, 09:06 PM   #17
Originally Posted by PaleMelanesian View Post
If you look at the tables on page 8, the results are different for crew/extended cab than they are for regular cab / long bed. Ext cab - tailgate up, reg cab long bed - tailgate down.
That was my experience as well, my '86 D-250 did get an improvement with the tailgate removed (std cab) but my '95 club cab did not.
Best I can recommend is do your own experiment, mythbusters is entertainment.
As for it up or down, I never understood this concept.
If up is the answer there is nothing more doing, have a nice day.
But if down is the answer then take it off and install an air mesh gate, saves another 20+ pounds of weight, why leave the stupid thing on?
Old 12-04-2007, 11:04 AM   #18
Bah, what a useless study. Why is it the only short beds they had were extended cab and the only long bed was a standard cab?
Does length of cab make a difference?
They studied full toneau or not, but why didn't they try with cap or not, that interests me greatly.
Also why do they continously admonish putting the tailgate down when the 8ft bed showed positive results at anything over 0 degree yaw (and not that bad of a negative effect at 0 yaw either).
I guess I should do my own experiments but without a scan gauge and at my low MPG the variance is so high I doubt there's any real way to tell what helped and didn't.
Old 12-04-2007, 11:28 AM   #19
RningOnFumes's Avatar
Mythbusters also tackled this issue. Basically, there is a bubble of air that is trapped in the bed causing the airstream to go over it as if there was something there. So tailgate up is best.
RningOnFumes is offline   Reply With Quote
Old 12-04-2007, 01:23 PM   #20
Last year when I was on a working trip to South Africa, I ended up on a race track outside Johannesburg where the local motor club arranged a speed trial open to anyone. They used a radar to measure top speed after the rather long start/finnish stretch. The cars were doing flying starts so most of them seemed to reach "terminal velocity". One of the fastest cars was a very turbo charged Japanese pickup. After a couple of runs, I suggested they should tuck the mirrors in and remove the tailgate to increase top speed. To my surprise, they got significantly lower top speed with that setup (sorry, don't remember the figures). They did try several times but it just didn't work. I never got an explanation to that until I started to read these forums...
GasSavers_HAHA is offline   Reply With Quote
Adding a Tank Size. Shifty54 Fuelly Web Support and Community News 1 04-13-2010 07:07 AM
Things To Look For When Buying A Civic Vx??? panamacolin General Fuel Topics 10 08-15-2008 04:57 PM
Sparrow Electric Car Matt Timion Electric and Solar powered 11 06-27-2006 09:50 PM
