New Front Air Dam w/ Pictures - Page 2 - Fuelly Forums
Old 07-19-2007, 07:04 AM   #11
GeekGuyAndy's Avatar
I drove around dirt roads a little yesterday, and the only time it hit was when I tried to hit the wheel into a pot hole. Even that just slightly bent the metal back and I could bend it back in a second. I think I'll keep this height until I find that it's a problem. I don't want to cut off more than I need to. I ordered the SGII, so I'll have to try A-B-A tests and see if/what the difference is.
GeekGuyAndy is offline   Reply With Quote
Old 07-23-2007, 04:55 PM   #12
Update: I was hitting the ground a few times, so I removed an inch from the bottom and it's doing much better now. I also bolted on a wood board cut into 3 sections (wide in the middle, shorter ones to the sides) so that it holds shape better and if it does hit the ground now, instead of a smaller area getting all the force it is spread over a few feet and requires less maintinence.
Old 07-24-2007, 06:09 AM   #13
brucepick's Avatar
Pic of the board/boards?
And can I suggest, once you find the ideal height for the air dam, you can add a belly pan going from lower edge of air dam to as far back under the engine/front suspension as you can make it reach.
I'll suggest 2.x mm. thick lauan plywood. In my area its about $7 for a 4x8 foot sheet. I used 5.x mm. thick for my belly pan, cost is about double that of the thinner stuff which I haven't tried yet.
Old 07-24-2007, 06:36 AM   #14
Or Coroplast, which is naturally waterproof and such...
Using a GPS for fuel economy ketel0ne General Fuel Topics 30 05-04-2009 12:59 PM
Question about soloenoid. omgwtfbyobbq General Maintenance and Repair 12 12-28-2006 10:42 PM
Looking for Insight wheel numbers GasSavers_Ryland General Maintenance and Repair 3 07-08-2006 11:02 PM
