Narrower Wheels or Lighter Wheels??? - Fuelly Forums
Old 06-20-2007, 06:56 AM   #1
Send a message via Yahoo to GasSavers_BMac
Question Narrower Wheels or Lighter Wheels???
Ok, I have a set of aluminum Dakota wheels that are 8" wide. I swapped them out for a set of steel 7" wide wheels.
Which is going to help in mpg gains if the aluminum ones are lighter?
1998 Dodge Dakota Sport 5.2 auto,
Aero Cap,
Cam advanced 4 degrees,
MSD 6TN,
MSD Blaster2 Coil,
MSD 8.5mm SuperConductor wires,
Borg-Warner cap & button
Halo plugs,
PCV jar
and more to come...
GasSavers_BMac is offline   Reply With Quote
Old 06-20-2007, 07:06 AM   #2
I vote the lighter wheels as there is less energy expended every acceleration (the angular momemtum increase and decrease will be less).
lca13 is offline   Reply With Quote
Old 06-20-2007, 07:08 AM   #3
brucepick's Avatar
I'm sure you'd need a wind tunnel to really nail it down however...
The aero profile of the wheel + tire is going to be determined by the tire's section dimension - the first # in the tire size. Both your wheel sets are going to be narrower than the tire's section dimension since the sidewall bulges out from the rim.
Based on that on piece of information only, I'd say the lighter wheel would win. However if it's aerodynamically very busy, and the wheel covers on the steelies are basically flat and smooth, then the steelies might be a better choice.
Of course steelies have virtually no bling appeal. Paint wobbly concentric rings on them to confound your observers.
Old 06-20-2007, 12:27 PM   #4
well i went from like 6" stock steel wheels to 8" aftermarket steel chrome wheels and didnt notice any difference in MPG. well nothign that couldnt be accountable from driving differently.
Old 06-20-2007, 02:40 PM   #5
When I bought my xB I went from steel to Enkei aluminum wheels. Saved right on 8 pounds per wheel. Kept the original 15" diameter. So my xB went from 2415# to 2383# and I reduced the rotating mass and the unsprung weight. All winning moves. The only think I wish is that the wheels were a bit more aerodynamic. I'm thinking of Moon discs, but that blasphemes the Enkeis.
I'd vote for aluminum wheels--if indeed they're lighter. Use a scale. Larger diameters may weigh more than steel.
GasSavers_Graeme is offline   Reply With Quote
Old 06-20-2007, 03:41 PM   #6
Consider that Honda put aluminum wheels on the VX, unlike most of the other models.
Any mass reduction in the drive train is a win. The performance guys even replace the flywheel for a few extra HP.
Old 06-21-2007, 03:00 AM   #7
Ok, then I guess I'll go back to the original meaty wheels. I felt more secure in the turns with them anyway.
Thanks
B~
Aero Cap,
MSD 6TN,
MSD Blaster2 Coil,
Halo plugs,
PCV jar
and more to come...
Old 06-21-2007, 04:18 AM   #8
psyshack's Avatar
You need to weight the wheel and tire combos.
A narrow plus light wheel tire combo will always be better mpg wise.
09 HCHII, w/Navi
07 Mazda3 S Touring, 5MT
Mild Hypermiler or Mad Man?
Windows vs. A/C DHA General Fuel Topics 7 11-19-2009 07:57 AM
to all SGII users w/ a gray plug GasSavers_Diemaster General Fuel Topics 5 01-05-2007 09:46 AM
Injector-pulse, Nissan Micra K10 ? GasSavers_elg General Fuel Topics 4 10-06-2006 04:43 PM
Diesel Kleen cetane booster diamondlarry General Fuel Topics 10 11-10-2005 02:27 AM
