My T-100 aero cap... - Page 9 - Fuelly Forums
Old 11-16-2015, 06:45 AM   #81
BamZipPow's Avatar
Send a message via AIM to BamZipPow
Wink
Had some time to work on the next belly pan since the weather was so nice.
Built up the support structure similar to the previous one. I think I figured out how to install the wheel belly pan since the air bag support is extended out. It will be based on the bolts that hold the air bag in place and will use spacers to build in an upper support rail to secure the wheel belly pan in place. The rail will not move up in down with the wheel fork but the rail will allow the wheel fork to move without interfering with the fork's movement.
I was able to use a scrap aluminum window frame as my crossbeam to attach my support rails fer the main belly pan.
A quick piccie of the updated belly pan...
Used 2 "L" brackets to make a "U" shaped setup.
A quick mockup of the belly pan...
I will install a 90 degree fer the air spring bag valve so it will be pointing to the rear and allow me to hook up a remove fill valve later.
Air valve installed...
Side rail view...
Another quick mock up of the belly pan...
BamZipPow is offline   Reply With Quote
Old 12-11-2015, 09:43 PM   #82
BamZipPow's Avatar
Talking
Current view from about 100' away...
Rear shot...
Old 12-20-2015, 07:14 AM   #83
BamZipPow's Avatar
Wink
Belly pan finished out to the end of the trailer and painted in white!
Old 03-06-2017, 05:22 PM   #84
BamZipPow's Avatar
My trailer now has triple beam support!
Old 03-06-2017, 05:29 PM   #85
BamZipPow's Avatar
Talking
Extra receivers bolted to the main hitch...
More Fuelly graphics? reppact Fuelly Web Support and Community News 5 11-30-2008 08:07 PM
Can you identify the wires in my o2 sensor? Matt Timion General Maintenance and Repair 9 07-11-2007 11:13 PM
Looking for someone to forward an eBay package from US to Canada MetroMPG General Discussion (Off-Topic) 9 06-27-2007 02:40 PM
Have you ever participated in a 'Cruise Night' in your city? Peakster General Discussion (Off-Topic) 20 03-27-2007 03:23 PM
I'm going nuts! buying tires soon lovemysan General Fuel Topics 11 12-23-2006 08:13 AM
