My Homemade Aero Bumper - Page 6 - Fuelly Forums
Old 09-24-2009, 08:33 AM   #51
GasSavers_TomO's Avatar
Originally Posted by Brontegirl View Post
I like the look as well. The vent to one side is very distinctive.
Is the vent to one side for a functional reason or is that purely styling?
Thanks.
The vent is where the radiator sits on the 92-95 Civics so it is purely function over form there.
I personally dislike asymmetrical styling on cars, but since I know it serves a specific function I let it go, lol.
Another thing that I wonder if using Good Stuff is safe on a car since it is flamable? *yikes!*
Open flame can set the great stuff on fire, but after it has cured for 24hours it takes direct contact with flame for about a minute to catch fire. The Great Stuff in the bumper is covered with Bondo and Fiberglass Jelly and the backside is enclosed and my car doesn't shoot out any flames, so It'll be ok
Honda Civic VX Info/Links
Old 12-18-2009, 05:22 AM   #52
oneinchsidehop's Avatar
Originally Posted by TomO View Post
I used Great Stuff expanding foam to lay down a backing for the fiberglass jelly to cling to. Then the final step was to shape and smooth the jelly and then skim coat with Bondo. And then paint.
Next bumper I'm making will use plastic welding though. It will be faster than the methods I used on this bumper.
Do you have any shots of the fabrication? That looks absolutely fantastic. You really got my attention with this one, any links on how-to do the Great Stuff/jelly process?
Mike
_______________________________________________
"If you want to save gas I suggest you permanently remove the drivers seat and steering wheel. That seems to help." -Oscar Halverson
oneinchsidehop is offline   Reply With Quote
Old 12-18-2009, 06:21 AM   #53
GasSavers_BEEF's Avatar
oneinchsidehop,
I actually started a thread similar to this one where I show how I did mine (youtube vid). I will admit that mine didn't come out as good as TomO's did but I like the results. we talked about it extensively in this thread above. he was a good resource and pretty much talked me through the process (good to have internet friends).
also, if it helps, I don't do body work. this was only my second attempt (counting the failed attempt to do this the first time).
remember that all cars are different so don't go closing off anything permanently unless you know your car is fine with it.
http://www.gassavers.org/showthread.php?t=11764
Old 12-18-2009, 06:38 AM   #54
oneinchsidehop,
Bookmarked!!! That was excellent, exactly what I was hoping for. And it looks GREAT.
Thou dost rawk.
Mike
Old 12-18-2009, 07:15 AM   #55
Thanks for fielding that one BEEF!
Good luck and glad that we could be ome inspiration for your project oneinchsidehop!
Old 12-18-2009, 07:25 AM   #56
remember that film quality hides a lot of flaws.
I think that you said it best (TomO) "we are our own worst critic"
also remember, the more time you spend on it, the better it will turn out.
I ended up purchasing a bumper from the local pull-a-part (junk yard) so that I could spend more time on it.
Old 01-12-2010, 07:28 AM   #57
Wow i like the whole front. Great fab work! Is the only openning there enough to keep your radiator cool, especially during summer. I'm from WI so i though i'd check. I've got a 99 front bumper, so that process could infact help me alot.
204snic is offline   Reply With Quote
Old 01-12-2010, 07:47 AM   #58
I assume you are directing that towards TomO.
I would suggest using plexi-glass or coroplast to cover your grill just to see how much you can get away with before you make it too permanent. I had my grill covered for more than a year before I did mine.
as stated above, all cars are different so you have to find out what works for you and also the average temps vary from area to area. in wisconsin you should be able to get away with more than people from other areas (more southern ones) because average temps should be lower.
I would say to experiment first and go from there.
Old 01-12-2010, 08:00 AM   #59
Go with What BEEF said and experiment with the opening first.
I had mine blocked for nearly two years before actually making that bumper so I knew what size opening I could use. It is big enough to keep the engine within normal operating temps on a 90?F day going 65mph on the highway for 4 hours, even with 45 minutes of stop and go traffic too.
Old 01-12-2010, 08:05 AM   #60
Thanks BEEF*. Plexiglass? Are there plexiglass that is strong enough, and bendable to be shaped for the openning? Where would be the best place to find something like that? Sorry, 1 more question for you (BEEF*). How do you cut the plexiglass (rotory saw? saw zaw?). Thanks
A suggestion to improve the site buttersnz Fuelly Web Support and Community News 4 08-19-2013 10:25 AM
Tips on Valve adjustment domggg General Maintenance and Repair 27 09-04-2008 09:38 PM
legal advice 93dagsr General Discussion (Off-Topic) 8 08-01-2008 07:12 AM
WTB HX or VX wheels S1K Wanted to Buy 2 04-28-2008 06:54 AM
'87 5.0ltr Mustang GasSavers_Loopie Car Reviews 2 02-20-2008 01:42 AM
