Modifying my Brick-On-Wheels - Fuelly Forums
Old 11-05-2009, 12:17 PM   #9
MTUboi86's Avatar
Send a message via AIM to MTUboi86
I agree about checking the level, but how would a dry differential result in the loss of a wheel?
Yea... I'm curious about the wheel myself. Only thing I can think of is the dry diff. built up so much heat, over time it weakened the axle... causing the wheel/axle to break off. Though, that's just my wild guess, I really have no idea. Seems like the Diff would seize up before anything else. Maybe that's what happened... the diff seized up, and with the tire moving at HWY speeds, it torqued the axle, etc too much and broke it off. *shrugs*.
So, before I emailed Royal Purple about fluids for my xplodr, I didn't even know there was fluid in the transfer case
4wd is important for me, so maybe I'll change that fluid... and then just check the diff. fluid levels and top them off.
What is diff. fluid supposed to look like? ... if it's no longer transparent, I'm just wondering if I should change it rather than top it off ... because don't these fluids lose their viscosity over time?
What I worry about with not changing the oil at least every 6 months is the anti-corrosion components of the oil losing their protective properties, creating havoc on my engine.
MTUboi86 is offline   Reply With Quote
Turtle Wax Ice gork57 General Maintenance and Repair 4 05-21-2009 10:11 AM
Conservative/Liberal Wyldesoul General Discussion (Off-Topic) 5 03-23-2009 07:32 AM
Electrorheology Leads to Efficient Combustion flapdoodle Experiments, Modifications and DIY 5 10-05-2008 01:45 AM
What should I do? CRX pruchase! pinbrew General Fuel Topics 4 04-30-2008 02:12 AM
Can't add to my Gas Log? DarbyWalters Fuelly Web Support and Community News 7 01-26-2008 05:14 AM
