Modifying a 98 Contour (pics) - Page 2 - Fuelly Forums
Old 08-19-2008, 05:42 AM   #11
thornburg's Avatar
I love the aero mods.
You should probably do something to make the tail visible, for safety's sake. I have no idea what would look really good, but the easy solution is simply to paint it.
Old 08-19-2008, 05:51 AM   #12
GasSavers_BEEF's Avatar
I used plexi for my grill block and I painted it with krylon fusion paint. I haven't had any issues and have had it on the front of my car for a couple of weeks. there are bugs splattered all over it.
it's like $5 a can or so.
Old 08-19-2008, 06:55 AM   #13
Draft a Semi at a separation distance of 125 feet (give or take whatever makes you feel comfortable), and watch the scan guage. You may be able to stay with the traffic and get better mileage, especially with better aero.
Use Rain-X on all the windows, been using it for over 30 years here. The better your aero the better the Rain-X works.
Rain-X also shows you when your drafting is effective, you can see the turbulence effecting the drops as they fly up your windishield.
regards
gary
Old 08-19-2008, 07:34 AM   #14
thornburg's Avatar
regards
gary
What is the best (cost + effectiveness) way to apply Rain-X? I use Rain-X windshield washer fluid, but that only has a minor effect (I like it anyway, it seems to work better at cleaning the windshield than most other washer fluids I've tried). I've seen Rain-X wipes (presoaked cloths), but I'm skeptical of them. Do you just use the kind that comes in a spray bottle?
Once, Jiffy-Lube gave me a free Rain-X treatment on my windshield, and that worked like magic, for a while (several months, IIRC), but it would be rather expensive to have Jiffy Lube Rain-X my whole car 4x per year...
Old 08-19-2008, 07:57 AM   #15
Loserkidwac's Avatar
Send a message via AIM to Loserkidwac
I used the rain-X whipes on my hatch and they seemed to work fairly well, I don't think they last as long as...but you can reapply it as needed, I need to do the del sol and see...gl I like your areo mods
MPG Noob
03 Mazdaspeed Protege
91 Honda CRX Si
95 Honda Civic VX *RIP 5/20/08
94 Honda Del Slow D15z1 Swapped
Loserkidwac is offline   Reply With Quote
Old 08-19-2008, 01:55 PM   #16
I've used the Rain-X washer fluid in my truck for years. I've found it works just as well as a regular Rain-X treatment, at least on my vehicles. I haven't applied Rain-X with a bottle in about 5 or 6 years.
Old 08-19-2008, 03:02 PM   #17
Originally Posted by oneinchsidehop View Post
Keep playing with speed on your route, in the Subaru I have now 45mph=21.5mpg on average, 65mph=20mpg, but holding the throttle steady and letting the speed range from 40-67mph=27mpg. The end of route ET is about the same as doing 60mph on cruise control. In my car it's not a battle of aerodynamics, but a battle of a really horrible transmission and 4wd system, it seems your Contour is a MUCH better platform. If you haven't done the coast down calculations you'd probably find them very, very helpful.
I haven't gotten a chance to use my car on my daily route yet. In the summer I drive a bike and my wife drives the car instead of her van.
The Subaru drivetrain has its advantages, they just don't happen to be FE related ;-) but judging from your pic, you make use of it in the slippery white stuff so it is probably easy to justify.
I definately need to do some coastdown calculations. I think I will learn a lot from them, plus I want to try some other mods to test too (so I can have the same baselines with numerous aero mods). I would really like to make some home made VGs and then put them at the rear of the roof, testing the different spoilers with and without the VGs, and with a common baseline.
-Mr_C
GasSavers_Mr_C is offline   Reply With Quote
Old 08-19-2008, 05:28 PM   #18
The original form of Rain-X -- concentrate. You squirt a small amount on a cloth and wipe the car. It doesn't take much. It's a lot more work than just dumping some in your washer fluid or using Rain-X brand washer fluid.
Old 08-20-2008, 05:08 AM   #19
oneinchsidehop's Avatar
First and foremost: Scrub the living bejebus outa the windshield.
It has to be antiseptically clean to work well at lower speeds. I've used windex+newspaper followed by bug remover, then windex, then alcohol.
It will also give you a good view of the air flow across the glass surfaces, esp on the rear window.
Mike
_______________________________________________
"If you want to save gas I suggest you permanently remove the drivers seat and steering wheel. That seems to help." -Oscar Halverson
oneinchsidehop is offline   Reply With Quote
Old 08-20-2008, 05:46 AM   #20
I use an old scrub brush when I wash the car, do the windshield first, then do it again after the glass has been wet for a while to soak the really hard gunk. I use dishwashing liquid for soap.
I use two old towels to dry my car, and wipe the windows off, inside and outside. Wet towel first, dry towel second.
I use the old spray bottle Rain-X. I redo the windshield about once a month. The side and rear windows I do about once every six months. I use the same bottle for years for my one car. I like to let it dry, then buff it with a clean old towel. I usually use a paper towel for application, and let it dry for a few minutes.
It's one way I manage to drive my VX without intermittent wipers. I simply don't use the wipers most of the time. It also keeps the visibility high out of the rest of the windows. In winter I use an old wiper blade (all plastic) or a squegee to get the dew off the windows, but now I only park in my garage, so morning dew is not an issue. The garage also keeps my car warmer in the winter.
regards
gary
Maintenance cost tracking site Lonnie General Fuel Topics 0 08-16-2012 09:09 AM
Myspace group! repete86 General Discussion (Off-Topic) 8 11-16-2006 07:18 PM
