Metro aerodynamics - Page 18 - Fuelly Forums
Old 09-07-2006, 10:27 AM   #171
That's what I meant, yes.
So you're suggesting a 4-7% FE increase, or a 4-7% change in Cd?
Old 09-08-2006, 04:07 PM   #172
Spent a couple more hours on the tray this evening.
Old 09-08-2006, 04:26 PM   #173
zpiloto's Avatar
Originally Posted by MetroMPG
Anyway, the rear portion is in place. The hard part was coming up with a way to extend & taper the control arm surfaces upward toward the bumper and still allow flex in the tray to move with the suspension.
Nice. Don't forget to put the VG's under there
Old 09-09-2006, 02:06 PM   #174
The Toecutter's Avatar
Change in FE.
Old 09-09-2006, 02:18 PM   #175
zpiloto's Avatar
I'm going for 5% increase in FE. It will really help the P&G. I'm optimistic when do you think you'll be able to test.
Old 09-09-2006, 04:35 PM   #176
Finished tapering one of the control arms today (15 mins). I'll put in the time to finish it up tomorrow, and since I'm going away mid-end of the week, I'll try to get in some runs before I leave.
I'd be tickled to get +5%. Seems a reasonable estimate.
Old 09-10-2006, 05:42 AM   #177
Here's some info to use for an edumacated guess:
Old 09-10-2006, 09:26 AM   #178
zpiloto's Avatar
That increase would be at a steady state speed. I would think that there would be a better increase in your city driving even though the speeds are realitively slow because of the increase in coasting ability. Althought I think it would be impossible to quantify. Looking foward to your results.
Old 09-10-2006, 04:11 PM   #179
Recorded a couple of runs this evening with the undertray on.
Old 09-10-2006, 06:04 PM   #180
zpiloto's Avatar
I'll try to do temperature compensation calcs later, and see what that says, but the other thing I need to consider is that (a) I possibly made things worse by adding the tray, or (b) it didn't help any!
WOW 57 degrees nice I would really be suprised if it did not help there is too much data that say otherwise. Could you tell if the coast down were better? That's one thing that really jumped out at me was how much longer the speed took to bleed off and how much longer the coast was on my usual routes. Like you said need to test the same day. Just run the fireflea through the paces when you get back from your sea adventure. Got any pic's?
Is your vehicle set correctly? DTMAce General Fuel Topics 1 03-17-2010 05:21 AM
fuel economy question Creamycaesar General Fuel Topics 19 02-08-2010 07:37 AM
p07 ECU $15 Matt Timion For Sale 4 08-27-2006 11:25 AM
I will be bike riding across Iowa kickflipjr People Powered 11 08-02-2006 03:22 PM
Some glue that won't melt when it gets hot? SVOboy General Maintenance and Repair 16 08-01-2006 07:15 AM
