Metro aerodynamics - Page 15 - Fuelly Forums
Old 07-14-2006, 10:47 AM   #141
There was a lot of activity in this thread while I was away. Just got caught up on it all.
I love the Photoshop stuff. (Or Corel, Mark?)
The rear Metro wing and the boat-tails are great stuff. I was out staring at the back of my car last night, wheels turning (in my head) ...
Old 07-14-2006, 10:52 AM   #142
XFi
XFi's Avatar
Originally Posted by MetroMPG
For those who are interested, I have updated my site with a page about the XFi Aero Car that was posted in this thread in June.
Nicely done!
Great info...wish I could get some of those custom machined taller 5th gears! Would have normal gearing for 'power' and 'long legs' like yours!
XFi
Join us for the November 22, 2008 Pennsylvania Meet at Cabela's!
https://www.gassavers.org/showthread....634#post121634
XFi is offline   Reply With Quote
Old 07-14-2006, 10:56 AM   #143
Those custom gears would be the best of both worlds, wouldn't they.
Did you also send other questions to the Aero Car builder? If you heard back and have anything to add, please share!
Old 07-14-2006, 10:58 AM   #144
XFi
XFi's Avatar
Never heard anything back...emailed his son more than once, but didn't want to bug him anymore.
Good Follow up on your part!
XFi
Old 08-15-2006, 06:39 PM   #145
basjoos's Avatar
The Questair Venture provides a good example of an aircraft boat tail shape that could be easily adapted to fit a car. This very fast homebuilt has been called "the flying egg" and has a very short tail, but presumably has attached airflow to manage the speeds that it reaches. It has a 48" wide cockpit, comparable in width to that of a subcompact car.
http://www.aircraftpaintschemes.com/...AircraftID=367
http://www.airbum.com/pireps/QuestairVentureNose-on.jpg
http://home.triad.rr.com/mcintyre5/Questair.gif
http://www.wallacecompany.com/venture/
aerocivic.com
Old 08-16-2006, 07:32 AM   #146
basjoos's Avatar
Here are some line drawings of the Venture. Its tailcone seems to exceed the 10 to one ratio that people have quoted are being the sharpest taper that can retain an attached airflow. This aircraft is one of the fastest prop-driven homebuilts and holds a number of speed records in its class.
aerocivic.com
Old 08-16-2006, 08:15 AM   #147
My understanding is the "10" refers to max "degrees" (from vehicle direction of travel/air flow direction) that a plane can change inward. And one of the Chalmers reports shows that it's actually more of a range, from 10-20, with a sweet spot in there somewhere.
I also read a Phil Knox quote recently that says an elliptical curve (beginning from parallel to wind flow) to up to 20 degrees inward can still maintain attached flow - you just can't go to 20 degrees instantly. That's my understanding, anyway. Would explain the appearance of this airplane.
http://autos.groups.yahoo.com/group/maxmpg/message/809
Old 08-27-2006, 07:21 PM   #148
Coroplast to the rescue! Cut my front undertray this evening. Just some minor tweaking to get it done.
It will be relatively easy to install/remove, so I can probably do a test run with it as well. Eventually.
Old 08-27-2006, 07:39 PM   #149
Tomorrow! I'll take over for you at work.
Old 08-29-2006, 10:33 AM   #150
ZugyNA's Avatar
Celica wing seen:
Guess I could have gotten a little closer...but there are 2 small vertical wings that are angled inward at each end.
Is your vehicle set correctly? DTMAce General Fuel Topics 1 03-17-2010 06:21 AM
fuel economy question Creamycaesar General Fuel Topics 19 02-08-2010 08:37 AM
p07 ECU $15 Matt Timion For Sale 4 08-27-2006 12:25 PM
I will be bike riding across Iowa kickflipjr People Powered 11 08-02-2006 04:22 PM
Some glue that won't melt when it gets hot? SVOboy General Maintenance and Repair 16 08-01-2006 08:15 AM
