Magazine article - Page 2 - Fuelly Forums
Old 02-09-2007, 08:59 PM   #11
kwtorbe's Avatar
If you notice on a '69 Dodge Charger Daytona's there are two scoops facing the back of the car on the front fenders. These scoops hide the holes on the tops of the fenders that were used to release the air that got trapped in the fenders at high speeds. Dodge told Nascar they were for tire clearance to prevent ford and chevy from using their idea. They came up with these from extensive wind tunnel testing. New cars don't have the open inner fenders though like the old cars so I can't see how it would benifit most newer cars to cut holes in the tops of the fenders.
I read that posted link in hot rod a long time ago. Pretty sweet.
kwtorbe is offline   Reply With Quote
Old 02-12-2007, 05:13 AM   #12
Anyone else who read the article? It's still not up on their website, being as it is in the current issue.
I've been thinking alot about notch angle lately and what angle/height of lip spoiler would help my car out. As the article defines it, notch angle is the angle between horizontal and a line drawn between the tip of the trunk or spolier and the back end of the roof.
For those not familiar with a LeBaron, my car looks like this:
I'm sure the line of the rear glass is not helping me at all which is why I am interested in a spolier. The glass is nearly vertical and I notice that once I am above 45mph or so, any water droplets on the rear glass stay stationary. I'm pretty sure that this is indicating flow seperation, and if I could get a spolier back on the trunk to increase the pressure on the rear window without significantly lowering the pressure behind the trunk, I ought to see something.
GasSavers_BluEyes is offline   Reply With Quote
Old 02-12-2007, 10:59 AM   #13
kwtorbe's Avatar
Interesting.....I hope it works.
Old 03-08-2007, 02:51 PM   #14
Try a little one first, that is what I'm going to do on the lincoln. (simalar box on box profiles)
Old 03-11-2007, 06:57 PM   #15
Lucky me. I found a copy of the mag at my local Winn-Dixie. Was suppose to be displayed until Feb 13, but as luck would have it somebody failed to remove it!
The article was really good! Answers a few of my questions. Actually a lot of them....
The big one for me was the front air dam. The addition of a HUGE air dam which is what I will have to install outweighs the additional frontal area. That's great news.
The other biggie for me is the convertible top. What to do to smooth it out? I'm leaning on placing a 2" tall edge on the top of the windsheild. Will act the same as the air dam under the front bumper. If it works to keep air turbulence under the car it should do the same for the top? However, without thousands of dollars to rent the wind tunnel????
Lots of things they said that I didn't know was the use of speed tape. Tapeing the seams did nothing to the CD as well as making a flare in front of the rear tire. It only added 40 pounds of down force but no improvement in CD's.
Anyhow, great reading!!!!!!
brelandt is offline   Reply With Quote
Old 03-12-2007, 04:39 AM   #16
I really doubt that air dam will work on top of the vehicle though. The air dam works for the underbody because the air cannot 'fill in' behind it very effectively due to the ground being there. The reduction in turbulence is just because there is less air there.
I think a better fix for a convertible top would be to have it adjusted (if possible) so that it's not loose and flapping in the breeze. Or find a hardtop to replace the fabric.
Old 03-12-2007, 06:25 PM   #17
I actually thought about that "AFTER" I opened my dumb mouth! LOL!
Since a hard top would cost $1000 and my truck is only worth $500 there is no way I'm going that route.
Thinking more along the lines of using metal flat bars. Place 3 or so from front to back may do the trick.
Remember Login on Mobile page lunawire Fuelly Web Support and Community News 3 08-30-2008 08:33 AM
Any way to account for missed fuel ups? seanmnaes Fuelly Web Support and Community News 5 08-12-2008 04:48 AM
Saturn has died! (at least for now) diamondlarry General Discussion (Off-Topic) 73 07-01-2006 05:27 PM
New Theme Matt Timion Fuelly Web Support and Community News 3 09-26-2005 03:01 PM
