Low rider - Fuelly Forums
Old 04-09-2009, 07:58 AM   #1
Question Low rider
Drag can be reduced by lowering a vehicle.
My Blue Beast sits way up high on its axles, even with stock tires. This is really good for hunting and fishing trips in mud and snow. Off road mobility is the main reason I own such a tall vehicle.
But my highway mileage sucks, in part due to the height. I'm looking for suggestions to reversibly (and cheaply) lower my truck while driving to and from my camp, but then revert to normal height it when I go off road.
Has anyone done this in a full size 4x4?
Old 04-09-2009, 08:06 AM   #2
If it was a half-ton 4x4, you could adjust the torsion bars to lower the front. All you do is jack the truck up, turn a set screw, and lower it. However, your truck has leaf or coil springs, right?
How often do you expect to switch heights? I don't think there's a cheap way to do it easily (except on the half ton 4x4 as described above).
Old 04-09-2009, 08:10 AM   #3
Perhaps a removable air dam could get you some of the benefit?
co de pen den cy
Function: noun
Date: 1979
Old 04-09-2009, 08:27 AM   #4
GasSavers_BEEF's Avatar
here is a guy that did just that.
http://www.gassavers.org/garage/view/1285
he did it up real nice. I liked the way it turned out.
Old 04-09-2009, 10:16 AM   #5
I don't know what to suggest for adjustable ride height, but how about an aero bed cover? -
http://ecomodder.com/forum/showthrea...d-cap-583.html
Bill
Nrggeek is offline   Reply With Quote
Old 04-09-2009, 10:20 AM   #6
Interesting that his air dam has a gap in the center. Guess he figures air must be going more sideways than up. Or it was just hard to do.
co de pen den cy
Function: noun
Date: 1979
Old 04-09-2009, 11:21 AM   #7
I think at first he was going to have an adjustable flap there for some reason. I can't remember the reasoning but I remember him talking about it.
Old 04-09-2009, 01:27 PM   #8
The truck has leaf spring front and rear.
My first thought was to remove the shocks and replace them with double-acting air cylinders to pull the truck down. Air cylinders are cheap. But then I'd have no shocks. And I'd need a compressor.
I also thought about a set of springs to do the same thing. I'd disconnect the springs when I got off road. But where would I get tension springs?
Old 04-09-2009, 01:29 PM   #9
There are air bags specifically for raising/lowering trucks...
Old 04-09-2009, 01:30 PM   #10
wouldn't the air cylinders act as shocks as long as you have no output for the air. wouldn't it be like a shock absorber?
I'm not big on shocks so I'm not sure about it but it makes sense....maybe
Data/Chart Discrepancy PTH Fuelly Web Support and Community News 3 07-02-2010 08:14 AM
SMS fuelup went to wrong car todd Fuelly Web Support and Community News 4 03-17-2010 03:31 AM
How does Automatic Tranny choose? GeekGuyAndy Transmissions and Running Gear 5 08-13-2007 05:05 AM
Hypermiling Auto Trans w/ Tach brucepick Transmissions and Running Gear 4 04-12-2007 12:32 PM
