Lawn edge side skirts - Fuelly Forums
Old 08-31-2007, 06:32 PM   #1
holypaulie's Avatar
I'm planning to make side skirts out of the lawn edge. Can someone give me an idea how to mount them ?
Old 09-01-2007, 02:44 PM   #2
GasSavers_TomO's Avatar
If your civic has factory side skirts that can be removed, I would remove them and then attach the edging to the side skirt, then mount the side skirt back on the vehicle. That way you would retain the versatility of the OEM side skirt but gain the FE of the edging skirt.
Honda Civic VX Info/Links
Old 09-01-2007, 05:27 PM   #3
holypaulie's Avatar
The civic what I own honda doesn't make with side skirts. But your idea is good.
Old 09-01-2007, 06:33 PM   #4
brucepick's Avatar
Good idea - lawn edging for side skirts. I've been thinking plywood for the skirts but lawn edging sounds good.
To mount, I've considered getting furring strips and cutting lengthwise diagonally.
OK, I know that is guaranteed to confuse. They are about 3/4" x 1.25" x 8' long. Cut so it makes a wedge that's 8' long, trim that down to about 5' long so it fits your car. Wedge goes under the edging so the edging "hangs" vertically, not tilted at an angle. Then just use sheet metal screws through the edging, then through the furring strip, then into the sheet metal. If you spend the time and money you probably can find black-finish sheet metal screws, maybe round-head for better aero.
Nice thing about lawn edging is, if you take a speed bump a bit too fast or hit anything with the skirt, it will just bend and go right back into position. Plus it will probably look great with very little effort.
Old 09-02-2007, 04:18 AM   #5
oneinchsidehop's Avatar
We used to do this with track cars (legal with scca at the time) aluminum stock from a home depot like place works best then use sheet metal screw / washers to hold it in place. Crude, very crude, but it works. It doesn't need to be as far outside as possible either, following the rounded countour of the door looks much nicer and tend to hide the wrinkles and warps (yep, you'll probably get them) I do think a belly pan even if partial may be more effective though.
It does work GREAT for a cheap front air dam though.
Mike
_______________________________________________
"If you want to save gas I suggest you permanently remove the drivers seat and steering wheel. That seems to help." -Oscar Halverson
oneinchsidehop is offline   Reply With Quote
Old 09-02-2007, 08:14 AM   #6
billynjoanna's Avatar
I used the edging for my front air dam. The only thing is that when you lay it out it is not straight. There is a curve to it. I found that if you take a blow tourch to it ( being very careful not to over heat it) you can get it soft enough that you can shape it to fit what you need.
He who lives the longest WINS!
billynjoanna is offline   Reply With Quote
Old 06-06-2010, 01:51 PM   #7
Good idea! When I built my airdam it was summer so I left it out in the sun for most of the day, here in the southern states. It was very pliable, but warm to the hands. Throwing this info out to help others.
LarryClapp is offline   Reply With Quote
Someone has got to do this. omgwtfbyobbq Experiments, Modifications and DIY 16 05-31-2007 08:06 PM
Almost blew my tires today. repete86 General Fuel Topics 27 12-22-2006 11:12 PM
Finally made it! GasSavers_TomO Introduce Yourself - New member Welcome 13 11-13-2006 09:00 AM
where do I buy insulation? Matt Timion General Discussion (Off-Topic) 5 05-24-2006 07:40 PM
