improving a "battleship" - Fuelly Forums
Old 01-10-2008, 02:15 PM   #1
Well with my truck there was no rear quarter panels, just like another cab chassis/ flatbed out there. So I was thinking that if i was getting 17 mpg (20 on highway) without any panels, i could hop it up with some fabbed panels.
all this was exposed along with diesel tank
http://s274.photobucket.com/albums/j...t=P1100032.jpg
first off a little prototyping in foam
http://s274.photobucket.com/albums/j...t=P1100042.jpg
then some 1/4 luan just have to blend it to the body tomorrow and paint
http://s274.photobucket.com/albums/j...t=P1100047.jpg
and here is the full view
* oh I also popped off the headache rack, must have removed at least 3 sq ft of frontal area
ajac is offline   Reply With Quote
Old 01-10-2008, 04:04 PM   #2
GasSavers_Red's Avatar
Looks good. Wondering what would happen if you extented the panels to hub height or to the bottom of the rim then wrap it back to the frame?
Welcome to GS
Old 01-11-2008, 12:13 PM   #3
kamesama980's Avatar
or just see where it sits at max capacity and leave about an inch of clearance at that point.
-Russell
Old 01-11-2008, 06:21 PM   #4
HAHA , max capacity that is a good one. max capacity is about 3-4 ton on payload. but that wont be functional for me. because in upstate ny hills and pot holes would ripoff anything lower than 8 inches from the ground.
well besides that today before work i painted the panels flat black, all sides. it is looking pretty good i'll get a pic tomorrow, as well as fill the tank. and then we'll see if mileage improves.
*on the plus side cabin noise is down drastically, now it is a dull roar
Old 01-12-2008, 10:36 AM   #5
Good start, ajac.
2000 Ford F-350 Super Cab Pickup
4x2, 6 speed manual
Regeared to 3.08:1
4 inch suspension slam
Aero mods: "Fastback" fairing and rugged air dam and side skirts
Stock MPG: 19
Summer MPG: 27.0
Winter MPG: 24
Big Dave is offline   Reply With Quote
Old 01-12-2008, 10:55 AM   #6
ah, good ol' new york...you could make it out of assembly line rubber like I've seen some guys make front air dams for trucks out of. that's stuffs pretty durable. only make the mottom foot or 2 out of it for cost reasons. I'm just throwing out ideas here
-Russell
Old 01-13-2008, 12:45 PM   #7
yeah is doesn't help that the ski resort i work at doesn't plow or at least have a paved lot. then all the back roads is is great fun when they aren't plowed i feel like i am going to burst something, everyday.
her she is
http://s274.photobucket.com/albums/j...30023small.jpg
how about this? keeping it all flat like a hinging tonneu cover set at a slant, that way it can still be used as a truck.
http://s274.photobucket.com/albums/j...tbacksmall.jpg
The question is will there be any gain to having a 16" over 96" (8') slope versus a 16" high flat box. Which would be similar in height to a normal bed witha tonneu cover
Old 01-13-2008, 05:03 PM   #8
If you are making a fastback cover then you want to have it running from flush with the roof at an angle of 11 degrees to the back of the truck so you would drop about 18.5 inches (if my trig is right) across the 96 of the bed. If you look at the following diagram under the "A" column it shows the drag and lift produced my a fastback shape at different angles with the lowest drag at 11 degrees:
So there is a definite advantage to have sloping rather than horizontal because as long as the air stays attached (and it will at 11 degrees) you would be reducing the area of your wake which is what slows you down the most. It might also be good to have the last bit of the fastback curve back to the horizontal so that you aren't producing any lift. You could use plexyglass for a rear window in the cover if you are worried about viability.
GasSavers_mattW is offline   Reply With Quote
Old 01-14-2008, 08:14 AM   #9
I have been thinking about that. But since it is actually my moms spare truck that I am driving since my truck's motor blew due to lack of coolant by the origional owner. So I am only doing minor things. That she agrees to. The full tear drop wouldn't work with that truck, i would love to do it. The truck is used as a truck, it moves industrial machines from shop to shop.
Plus a sheet of polycarbonate 4' x 8' would run me $100. While I am trying to do what I can with little to no cost. I have $10 in spray paint only so far.
Old 01-14-2008, 05:50 PM   #10
Question for mattW: Where did you get those curves? I?d need to peruse them more closely. Obviously one want to produce minimum lift (positive or negative) if drag minimization is desired as we do. I thought my 17 degree setup was good but if 11 degrees is better, maybe I better reconsider. This makes sense. These exotic solar-electric cars are of nearly flat slope. 11 degrees might well describe them.
4x2, 6 speed manual
Regeared to 3.08:1
Stock MPG: 19
Summer MPG: 27.0
Winter MPG: 24
1992 Honda VX cfg83 For Sale 7 03-03-2007 01:08 PM
Traffic experiments Spule 4 General Discussion (Off-Topic) 3 12-22-2006 09:16 AM
Anyone know anything about shirt making SVOboy General Discussion (Off-Topic) 3 09-05-2006 12:07 PM
Long EOC no brakes at the bottom GasSavers_Jack Hypermiling 32 06-19-2006 09:48 AM
