Ideas to build Active grill ? - Page 2 - Fuelly Forums
Old 02-25-2008, 07:43 PM   #11
Your system is very good. I have removed the air dams on my Saturns and blocked the grills. I am thinking of using a panel behind the bumper on the bottom that I can pivot down to catch the air. The air would go up and through the radiator when needed. No drawings yet. If I put a large air dam on the car I will need to copy your idea.
Originally Posted by tweakmenow View Post
This is for my 97 Honda D16Y8. A choke cable easily moves a coroplast door, sliding on rails cut from a rain gutter leaf shield. A small square piece of aluminium with a set-screw locks the cable in proper position. The rails were siliconed to the vehicle. I keep the door fully closed until the Scanguage reports the water temp to operating range. Then, depending upon the OAT and vehicle speed, I know just how much to open the slide. During long EOC. I close the door to keep in the heat. Total cost for everything is $15.00
It's awesome to be able to operate this from your seat...
usedgeo
Old 02-25-2008, 08:26 PM   #12
Snax's Avatar
That looks like the most reliable way to do it.
Nice job!
LiberalImage.com
I think, therefore I doubt.
Old 02-25-2008, 08:34 PM   #13
boxchain's Avatar
I'm gonna put my money on gravity/airflow/spring-loaded doors doing a lot of flapping around in the wind. Then the flapping will drive you nuts, you'll pull over, then you'll rip it to smithereens if it hasn't already self-destructed.
Yeah, maybe. I'm just afraid of doing a grill block with our 7 months of 90 degree weather.
And if anything, I tend to overbuild, so I'd have to be the one to rip it out
boxchain is offline   Reply With Quote
Old 02-26-2008, 01:11 PM   #14
cfg83's Avatar
theclencher -
Ha ha, good point. I can see Homer ripping it to shreds! Here's another variation on the same :
Attachment 1213
The "slow speed" state would have a gap between the flaps for wind to get into and open it at higher speeds. There would have to be a spring somewhere to "push it back" at slower speeds.
higher Octane = Better MPG JBW General Fuel Topics 9 04-04-2012 12:54 AM
View model averages? unicrombie Fuelly Web Support and Community News 4 11-09-2011 07:32 AM
I just lost some weight (166lbs) kickflipjr General Fuel Topics 21 04-12-2007 12:27 AM
Got stopped by the police ... MetroMPG General Discussion (Off-Topic) 14 08-05-2006 07:04 AM
Toyota Grand Prius krousdb Automotive News, Articles and Products 5 07-26-2006 03:44 PM
