I can dream can't I? - Page 3 - Fuelly Forums
Old 05-28-2007, 03:03 PM   #21
Originally Posted by MnFocus View Post
Better start saving now 17 years is 'barely' enough time !
The kitcar method is right here about 10 threads down , either '1st big test' thread or 'my videos' . He did a pretty good demo using a propane torch and a workmate .
A g2g might be a pretty neat deal .
Darn easy to do. Just be careful with the heat. You don't need the apex of the flame tip but the outer light part of the flame. It's a gradual heating process. Too much heat will make it brittle. You can do a grill blocker without a workbench. Attach one side (top or bottom) to where it's going to be and gradually heat the stuff applying pressure to form it to the shape. Finish attaching and you're good to go!
Another thought (GM actually came up with this) is that you don't really need to totally block the grill off. A lot of Dodge Dakota guys use (honest to God) metal gutter guard as a grill guard. Rocks can't get through those little holes. This also blocks air. That's why GM SUVs and trucks have those metal inserts in them now. They did a test in 2000 on a Silverado with cardboard taped on it including blocking between the body and frame.
Proud owner of Stinkerbutt!
[SIGPIC][/SIGPIC]
-Homebrew front air dam
-Homebrew side skirt
-Torza top bed cover
Old 05-16-2008, 11:03 AM   #22
What do you think has the least effect on temp - blocking the upper or lower grill? (Like the ones on this Focus)
VXer is offline   Reply With Quote
Old 05-18-2008, 09:30 PM   #23
Originally Posted by holypaulie View Post
I used thin aluminum sheet for my grill block. I only wonder if its enough air flow.
Attachment 500
Very professional looking. And cool looking too !
It looks like something that you would see done at a speed shop.
Nice touch having the aluminum which matches the car.
Have you noticed any MPG gains ( lazy. didn't read entire thread )
Nerds laugh at me is offline   Reply With Quote
Old 05-19-2008, 05:28 AM   #24
holypaulie's Avatar
Thanks. I've change my lower grill block a little bit. Now the lower grill is covered 50% for better cooling. I have noticed 3 more MPG on highway with that modification. I'm planinng to make rear wheel skirt pretty soon and see what kind of gains I will get
