How would someone go about lowering a Geo Metro? - Fuelly Forums
Old 02-25-2007, 11:23 AM   #1
Peakster's Avatar
Question How would someone go about lowering a Geo Metro?
Originally Posted by MetroMPG View Post
- reduced ride height (3 inches is often quoted as optimal)
I'm seriously considering to lower my Geo. My old Fiero had a ground clearance of around 4.5 inches (with the tiny P185 70 R13 tires) and wouldn't mind if the Geo was the same.
Attachment 226
VS
Attachment 225
What is the least expensive method of doing so (without throwing out alignment to the tires)?
Old 02-25-2007, 11:32 AM   #2
You'll throw out the alignment a bit no matter what...I wouldn't cut your springs, because it will affect the spring rate...you can always buy lowering springs, the GT version might be lower?
You could also try to find other cars with same radius springs and try to find some lower...?
Old 02-25-2007, 11:58 AM   #3
Peakster's Avatar
The GT version does appear to be lower, but finding GT springs at a decent price will be difficult.
Waterboy lowered their metro by 2":
Attachment 227
I'd give them an E-mail of how she/he did it, but this member hasn't been online since December 2006. The front wheels seem to be aligned ok, but the rear ones look a bit wonky.
Maybe I should just stop the next lowered vehicle I see on the street and ask them how they did it.
Old 02-25-2007, 02:21 PM   #4
skewbe's Avatar
http://www.google.com/search?hl=en&i...er+cut+&num=25
Standard Disclaimer
Old 02-25-2007, 02:24 PM   #5
CoyoteX's Avatar
I cut the springs on my car and have it sitting within 1/2 inch of the bump stops. I am not sure how much it is lowered from factory but probably at least 2 inches or so. It rides much better, the factory springs are way to soft and could use a bit of stiffening.
Old 02-25-2007, 03:49 PM   #6
Peakster's Avatar
I guess I could always try finding springs from another Metro, cut them, and try them out. That way if there is a big tire-wear issue, I can always put the originals back on.
If and when I do lower the car, it's going to be a considerable drop (just measured the ride height and it's 9 inches! ). 1/2 inch from bump stops might be in order.
Old 02-25-2007, 04:23 PM   #7
Yeah our gen 4&5 cars are odd in how much ground clearance they have.
Also, the later cars had stiffer springs. I talked to Waterboy (it might have been someone else with a chopped spring mk5) and he said his car is pretty harsh after the chop. If he could undo it, he would have cut less.
It has been said at teamswift that the mk3 cars had softer springs, so you might want to see if you can get a set of those to cut. The ride won't be so brutal afterwards.
Old 02-25-2007, 04:31 PM   #8
Peakster's Avatar
Thank you for the advice MetroMPG!
Old 02-25-2007, 04:36 PM   #9
Sure thing. Might want to verify the spring rate & intergenerational swappability though. Don't believe everything you read
Old 02-25-2007, 06:19 PM   #10
cfg83's Avatar
theclencher -
I'd cut the springs for a mild lowering job but not for a big slam.
I have cut the springs on my Lambo and am very satisfied with the results.
Do a search- this has been hashed out here before.
Here's one :
Best way to do a lowering experiment?
http://www.gassavers.org/showthread.php?t=1776
Throttle Position During Acceleration and its effect on FE SVOboy General Fuel Topics 105 06-09-2009 02:33 AM
'93 Civic CX Hatch - d16B8 rh77 Experiments, Modifications and DIY 15 02-13-2008 10:52 AM
I will be bike riding across Iowa kickflipjr People Powered 11 08-02-2006 03:22 PM
New forum guidelines, FAQ Matt Timion Fuelly Web Support and Community News 14 05-21-2006 06:26 AM
Hybrid Scooter kickflipjr Motorcycles 4 10-01-2005 01:31 PM
