Hood Gap Aero - Fuelly Forums
Old 11-08-2007, 05:54 PM   #1
Hood Gap Aero
I took a look at the hood of the 'Teg the other day and realized something. The hood is right in-line with the major airflow of the car. You can see what I mean from a lighter-colored model (pic from Wikipedia):
The gap doesn't sit tight -- there's a rubber seal, but daylight can be seen through mine, which means cold air has to be rushing in.
I really need to seal this up for the cold, and this is one piece of several planned. Any suggestions???
Old 11-08-2007, 06:03 PM   #2
trebuchet03's Avatar
Weather stripping
11/12
Old 11-08-2007, 06:12 PM   #3
Originally Posted by trebuchet03 View Post
Weather stripping
So the foam tape stuff (single-sided adhesive)?
I worry about building up too much of a gap for aero. It might be possible to weight-down the hood or adjust the mechanism to close tighter, but I don't know if those are viable options...
Old 11-08-2007, 06:13 PM   #4
skewbe's Avatar
if it is small enough you can fill it smoothly with caulk.
clean the area where the caulk will be attaching, spray some wd40 on the bottom front edge of the hood and fill the gap with white (black) silicone caulk and make it smooth with a finger. Wait till it cures before opening and open carefully. It should release from the wd40 side and leave a nice custom smooth looking seal.
Standard Disclaimer
Old 11-08-2007, 06:26 PM   #5
GasSavers_TomO's Avatar
you could also use colored duct tape, or move the latch mechanism that sits in the radiator core support down further. Don't forget to adjust the rubber spacers by screwing them down once you do this.
Honda Civic VX Info/Links
Old 11-08-2007, 06:32 PM   #6
If you get the soft squishy type, it should compress to form fit without increasing the gap...
Someone in another thread mentioned using expandable spray foam... Put plastic wrap (spray with some cooking oil so the plastic releases) where you don't want it to stick spray the foam on and close the hood - let it cure and lift the hood... Seems like it should work
11/12
Old 11-08-2007, 07:21 PM   #7
Snax's Avatar
The rubber bumpers on most hoods screw in or out to adjust closed fit. Try screwing yours in a turn or so if they are that type.
LiberalImage.com
I think, therefore I doubt.
Old 11-08-2007, 07:35 PM   #8
i wonder why they dont come weatherstripped
It has a rubber seal, but over the times the body panels have been removed and put back together (hail damage repair, ice impact repair), things don't line up like they used to. The rubber is a bit worn and squished too.
Good suggestions so far. I like the idea of tightening the gap with movement of the latch, and using something foamy to seal the deal up front. Along the sides, I might try the caulk method.
Old 11-08-2007, 07:50 PM   #9
ajohnmeyer's Avatar
Send a message via AIM to ajohnmeyer
Racing-Type hood pins would be the ultimate fix, though probably a last resort.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." -The Drive By Truckers
Team OPEC Busters!
ajohnmeyer is offline   Reply With Quote
Old 11-08-2007, 08:16 PM   #10
Danronian's Avatar
I owned two Integras and with some shimming of the bumper-cover up (with washers underneath it), and with some adjustment of the hood latch down, you can make your gap smaller. In more extreme cases, with the bumper cover off, you can bend up the upper rad support (quite easy to bend it really) slightly to further reduce the gap. The rubber seal sometimes does get a little flattened but usually it's not the only reason for the large gap.
Trying to add a car bw61374 Fuelly Web Support and Community News 1 08-17-2013 07:14 AM
Fuelly Mobile Location Data xbadcrcx Fuelly Web Support and Community News 4 06-29-2011 05:00 AM
AIR CAR. Motors run on compressed air. GasSavers_RickyD General Fuel Topics 24 06-22-2007 10:17 AM
elg's Project zpiloto General Fuel Topics 2 03-03-2007 06:47 PM
I'm going nuts! buying tires soon lovemysan General Fuel Topics 11 12-23-2006 08:13 AM
