trebuchet03 -
Originally Posted by trebuchet03
If you get the soft squishy type, it should compress to form fit without increasing the gap...
Someone in another thread mentioned using expandable spray foam... Put plastic wrap (spray with some cooking oil so the plastic releases) where you don't want it to stick spray the foam on and close the hood - let it cure and lift the hood... Seems like it should work
I just did this for my car last week. I used this stuff, $4 a bag at a standard-issue hardware store :
Attachment 1046
My gap was so large that I actually double-stacked the tape in some places. But at $4, who cares?
I can't tell if it helps, but I do think it has been hotter under the hood based on the number of times I have been manually turning on the electric fan.
What I *really* need to do is go hog-wild with the squishy tape. There are lots of little gaps that could be filled. For example, I have tape on the top of the headlights, but I also need it all around the headlights.
