Well here are some shots of what was done during vacation. Not enough time, took much longer than anticiapted. So hot today my air compressor quit so end of sanding. First shots are of the prep work. Foil was an attempt at keeping the fiberglass from sticking were it was not wanted. This worked very well! If you decided to use foam as a pattern cover it with a coat of dura glass before fiberglass. This keeps the fiberglass from attacking the foam. Wish that was fore knowledge and not after! Oh well that is what learning is about.
Rust in inner fender well was sandblasted and primed with por15. Will be undercoated next time fenders off.
Last shots are of were it is at now. Had to get it driveable. My only ride for work.
This is the front extender will need more work and DZUS fastners.
This was an idea to let air caught in the front end out. What about it CO? should it be kept or filled. Looks kinda neat to me?
Side shot, bottom left rear corner will have to be opened up for more clearence. Thats what happens when you build it yourself. Lots of adjusting!
Rear: Had to trim the edge stiffener to clear hupcap, and may have to end up with a circular cut out for more clearence. Dzus fastners back here too.
As you can see lots done. LOTS more to go.
