FMIC vs SMIC - Fuelly Forums
Old 10-05-2013, 09:14 PM   #1
FMIC vs SMIC
Front Mount Intercooler vs Side Mount Intercooler
Car is a 91 Talon TSI AWD Turbo that comes factory equipped with a SMIC. I was wondering if a FMIC would generally make the vehicle more aerodynamic or less aerodynamic?
Thanks!
92 Protege DX 5 speed - Poor Man's Hybrid 40.96 MPG (city)
Thicker 2 row radiator, walmart hubcaps, Pepboys tires, 10w 30 Castrol HM, Jensen CD player, Roadmaster speakers, ebay hi-flow air filter, autolite 3924 plugs, stant superstat, NGK blue 8mm wires, LeBra car bra, no Exhaust Manifold heat shield, MX-3 Seats, bad A/C compressor
jj94auto is offline   Reply With Quote
Old 10-06-2013, 06:36 AM   #2
Well, technically in theory, if you put it in the front, I'm guessing that it would act as a partial grille block, but in reality there's probably no measurable difference.
Old 10-06-2013, 08:32 AM   #3
They both need to be in the air flow to work. So, assuming the same size, there shouldn't be a measurable difference.
Now, if you are buttoning up a stock car's aerodynamics, the FMIC might be a better choice. Sitting in front of the radiator means that only one hole is needed to get cooling to both. Where as the SMIC might need its own hole. The intercooler itself isn't slicker in the airflow, but it could allow a cleaner nose and belly pan.
Old 10-06-2013, 08:07 PM   #4
Thanks very much for your thoughts.
