Finished the underpan on my VX - Page 2 - Fuelly Forums
Old 09-05-2007, 02:52 PM   #11
1993CivicVX's Avatar
Boy I sure wish I could start paying attention to mods for my car. Well, if when I get the basics taken care of (like getting the car past inspection) I'll know where to go to start work on the underbelly pan and other aero mods.
Nice work TomO!
three stripes the charm!
Old 09-05-2007, 05:38 PM   #12
basjoos's Avatar
One advantage of having the underpan is your engine stays a lot cleaner and there's less road noise. Much of the "road noise" is actually wind noise generated under the car.
aerocivic.com
Old 09-05-2007, 06:18 PM   #13
GasSavers_TomO's Avatar
basjoos - I have noticed that road noise is diminished. Hasn't been long enough to notice if the engine bay stays cleaner, but I'd have to agree that it would since the dirt really has no place to get into the engine bay now except through the radiator opening.
1993CivicVX - The time for your mods shall come soon enough, lol, and thanks.
Nerds Laugh At Me - It's a mild steel exhaust system that I coated with High Temp aluminum content paint, so basically it's a crude form of aluminized steel. I do have a slight rattle where the flashing contacts the exhaust near the 90 bend. I am going to stuff a chunk of fiberglass in between the tube and flashing to stop it. It only rattles at startup and once in a great while at idle. I'm also thinking that I have a great template now to make an all aluminum underpan. but that isn't going to happen unless I come across a 6'x'10 sheet in the garbage, lol.
Honda Civic VX Info/Links
Old 09-06-2007, 01:26 PM   #14
Nice work Tom. Looks clean.
Hope it helps more than mine did! I suspect it will, because your ride height is significantly lower than the Flea's.
Old 09-06-2007, 03:23 PM   #15
philmcneal's Avatar
why not just use all aluminum sheets? isn't aluminum lighter than coroplast?
any prius owners did a underbody? if so post pics too!
Old 09-06-2007, 08:44 PM   #16
Thanks!
How much of an increase did yours make again?
I'm only expecting about a 2% maximum increase from mine.
Cost was a big factor in using the Coroplast vs. Aluminum sheet. And to have an aluminum sheet the same thickness of the Coroplast I used, would have been twice the weight and 10 times the cost.
Old 09-06-2007, 08:50 PM   #17
2% in A-B testing, 3 bi-directional runs for each of A&B. Speed was 90 km/h I think.
All else being equal (which it's probably not) I still think you'll see better gains because of the lower ride height/higher flow velocity underneath your car.
Old 09-06-2007, 09:13 PM   #18
I still wish I would win a SuperMID!
I still only do tank to tank averages so it'll still be a week to week-and-a-half before I can start to see results of my under pan. I installed it with 100 miles on the tank already too, lol.
Hopefully I can get a 3% increase as the front of my car is also lowered 1.25 inches more than stock. Time will tell.
Old 09-09-2007, 09:02 PM   #19
Awesome writeup.
I just went from a 92 CX to a 95 DX (hatch) that is setup more as a trackday car. It's my beater, since I have a 99 Si for auto-x/trackdays.
Anyway, I just lost about 10mpg in the changeover. I've been a bit of a hypermiler in that I was able to wring a best of 49.x mpg out of my CX (1.5" drop, skinny tires, VX diffuser, Akimoto cone filter).
The new one has a d16z6 swap, DC 4/2/1 header, stainless 2.25" b-pipe, stock axleback exhaust and Ground Control/Koni yellow suspension.
I just added a VX diffuser to the rear end.
I was surprised to see how much of an effect lowering the front end has. At the moment, the front is higher than the rear (former ownder had it jacked up for winter use) Since my suspension is adjustable, I'm going to drop the front an inch for a total of a 1.5" drop.
My question (after all this) is that I have a nice urethane lower lip for the front spoiler that I haven't installed (don't know if I want to attract more attention to the car). Do they actually do something to improve aero (in terms of efficiency) or does it add drag??
Great forum. Looks like I have a lot to learn...
thanks
gamby is offline   Reply With Quote
Old 09-10-2007, 08:33 AM   #20
The VX in stock form has the Front Urethane lip. If it's the stock lip then yes, go for it. But lowering the car dos more than just having the lip. If it's an aftermarket lip, what kind is it as some of those lips will add more downforce and drag than the OEM VX lip will.
Let the games begin! Matt Timion General Fuel Topics 4 12-12-2021 12:04 AM
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 11:54 PM
U.S. Cars Show No Fuel-Efficiency Gains in 2006 MetroMPG Automotive News, Articles and Products 3 04-26-2007 12:15 PM
New member from Akron Ohio, 2001 Saturn Sl1 Golf3r Introduce Yourself - New member Welcome 28 04-10-2007 04:22 PM
