Finally getting around to the front tray - Fuelly Forums
Old 02-05-2009, 03:36 PM   #1
I'm finally doing a hard front tray I tried window screen and didn't have much success. I picked up some Black coroplast and got started.
Old 02-05-2009, 06:09 PM   #2
here are some photos
after trimming the tails the notch is to clear an air con pipe
and what the road will see.
Old 02-05-2009, 07:17 PM   #3
aalb1's Avatar
Front tray as in a Grill Block? It's hard for me to gain perspective with it sitting on the floor like that.
MMMMMM... Black Chloroplast! How much did it cost you? My 3 coats of primer and 2 coats of satin black top coat are chipping off my side of the road chloroplast
Old 02-05-2009, 07:39 PM   #4
it goes under the nose between the bumper and the radiator core support I spent $25 for a 3x4ft sheet
Old 02-06-2009, 05:45 AM   #5
That looks just like what came on my VW from the factory.
aalb1, you could use adhesion promoter instead of (or before) primer. I found that flat black spraypaint sticks to glossy white coroplast well without any adhesion promoter or primer, though.
Old 02-06-2009, 07:28 AM   #6
GasSavers_BEEF's Avatar
be careful doing that.
I tried doing that on my cav and it overheated in less than a mile. now my car gets most (if not all) of its cooling from the bottom. we both drive GM cars so it may have the same affect. just be sure to take it on a short test drive first or make it removable.
I have contemplated covering part of that opening to make a smaller inlet since I can't cover the entire thing.
the black coroplast does look good.
Old 02-06-2009, 01:28 PM   #7
My car has an air dam ahead of the gap I filled so if anything this will help cooling. I took it on a 50 mile drive and temps stayed in the normal range. I may add a couple extra holes in my block just to be safe (summers are brutal here). below are installed photos (I also added front wheel dams too)
I'm planning to continue the coroplast back to the rear of the cradle then transition to stainless
Old 02-06-2009, 01:57 PM   #8
aalb1's Avatar
I think I'll stick to "Side of the Road Coroplast."
But i might have to go with the black coroplast when I make tire deflectors...
All of it looks great
Old 02-06-2009, 03:10 PM   #9
I paid $20 for my 4x8 foot sheet but it is white (and still sitting in my garage)
Old 02-06-2009, 03:22 PM   #10
Where do you get your coroplast?
A URL parameter to expand notes please. m1sterc33 Fuelly Web Support and Community News 2 04-17-2012 08:47 AM
Using a GPS for fuel economy ketel0ne General Fuel Topics 30 05-04-2009 12:59 PM
2001 Cavalier NH Titan General Fuel Topics 8 03-30-2008 08:09 PM
f/s 93 civic VX Olympia washington progsr For Sale 0 12-01-2006 02:12 AM
where do I buy insulation? Matt Timion General Discussion (Off-Topic) 5 05-24-2006 08:40 PM
